Towing - Fiberglass RV
Old 07-12-2020, 10:59 AM   #1
Trailer: Currently shopping
Ohio
Towing
I am getting 13’ Scamp with bathroom towing with 2016 outback. What do I need to add to my vehicle to maximize towing (Sway bars, additional transmission cooler, wired or wireless brake control, etc)? Any other suggestions would be appreciated.
Ftears is offline   Reply With Quote
Old 07-12-2020, 11:24 AM   #2
Towing
Congratulations on your new Scamp!!
Beware tongue weight. Your tow rating (2700#) is plenty for a 13’er, but the tongue weight rating (200#) is marginal. You’ll want to skip the dual LP tank option.
Not sure about a transmission cooler for a CVT. Check with your mechanic, or perhaps other owners of late-model Subarus will chime in.
I’d always go with a wired proportional controller if possible. I think your 2016 should accept a wired set-up. The Tekonsha P2 is a popular choice.
The 13’ Scamp is naturally stable, so a sway bar shouldn’t be needed for normal driving conditions. However, having one adds an extra measure of safety in an unusual situation, like a sudden gust of wind from the side or an emergency lane change. Your call.
Most important thing to avoid sway is proper weight distribution. Carry heavy stuff over the axle and toward the front to maintain a minimum 10% tongue weight. Too much weight at the back is the most common cause of sway. Make sure your ball mount allows the trailer to sit level or slightly nose down.
You may also need towing mirror extensions, since your Outback is narrower than the Scamp. Some Outback owners use them; others manage without.
Towing Definitions-Understanding Towing weight terms cpaharley2008 Towing, Hitching, Axles and Running Gear 49 06-19-2019 02:27 PM
Towing like you're not even towing? swoosh Towing, Hitching, Axles and Running Gear 18 07-30-2015 09:18 AM
Liability and overweight towing (split from Towing 13' Scamp...) Bob Miller Towing, Hitching, Axles and Running Gear 88 04-18-2014 05:10 PM
Towing fifth wheel versus towing bumper hitch drstock Towing, Hitching, Axles and Running Gear 67 02-20-2014 02:04 AM
