Trillium 4500 (quebec) - Page 3 - Fiberglass RV
Click Here to Login
Old 11-07-2017, 04:54 PM   #41
Trailer: 1976 Trillium 1300
Looks amazing, love it and looking forward to seeing the finished product
kootenaigirl is offline   Reply With Quote
Old 11-14-2017, 11:31 AM   #42
Seaross's Avatar
Trailer: Trillium 4500
Completed making my trillium window rock guard with turquoise decal.Click image for larger version
Now Need to make decal for door.Click image for larger version
Seaross is offline   Reply With Quote
Old 11-14-2017, 12:17 PM   #43
David Tilston's Avatar
Originally Posted by Seaross View Post
Now Need to make decal for door.Attachment 113775
Tom Young sells a nice silver version at:
www.trilliumrv.com
Under "Parts"
Old 11-14-2017, 04:27 PM   #44
Seaross's Avatar
Thanks David, looking for off white , like the top portion of my trailer, might just paint it, if I cannot find off white vinyl stick on.
Old 11-16-2017, 07:34 AM   #45
Gilles's Avatar
Trailer: Bigfoot 25B21RB, 2004
Quebec
As I can see Ross, you have a lot of fun with your new acquisition.
You will receive a lot of congratulations from the members accompanied by questions, during your first outing ...
Excellent work!
Gilles
Bigfoot 25B21RB.
Towed with Dodge RAM 1500 Echo-Diesel, 3.0 L., 8 speeds.
Old 11-19-2017, 01:49 PM   #46
Seaross's Avatar
Thanks Gilles, I need to complete all work prior to my trip next year in preparation for the 50th boler anniversary.
Old 11-29-2017, 05:49 PM   #47
Seaross's Avatar
Today installed rubber sided boat carpeting and 4 baskets underneath bedding area.
Old 11-30-2017, 04:45 PM   #48
Seaross's Avatar
Placed counter plywood and cut out holes for tv and wine cooler.Click image for larger version
ID:	114232Click image for larger version
ID:	114232 long counter.
ID:	114233 tv hole and wine bottle hole cooler.Click image for larger version
ID:	114234 USB/ 110v counter plug. Now to get round sink and punch out hole.
ID:	114235 tv out.
Old 11-30-2017, 04:52 PM   #49
ckayaker's Avatar
Really interesting to see your new layout is coming together!
ckayaker is offline   Reply With Quote
Old 12-02-2017, 03:53 PM   #50
Seaross's Avatar
It’s starting to look like a camper trailer.
I built shelving all around back of trailer with led spot lighting. Also built storage around bedding area And installed bed , banquet conversion. Also placed hole for kitchen sink.
ID:	114297 top shelving with led spot lighting.
ID:	114298 bedding layout 55x75 inches
ID:	114299 banquet sitting.
ID:	114300 storage compartments around bed with inside boat carpeting.
Old 12-06-2017, 05:34 PM   #51
Seaross's Avatar
Today started insulating top body portion of my trailer. Used Lepage heavy duty low voc spray cement for sticking aluminum double sided air Bubble foil to fiberglass. I was surprised how this spray cement can glue. Sprayed the fiberglass and then the bubble foil , waited 5 mins, and then glued them together, just make sure you align both materials properly, because you don’t get a second chance.
Old 12-07-2017, 09:36 AM   #52
Does your glue have a temperature rating?
Old 12-07-2017, 12:35 PM   #53
Seaross's Avatar
Application must be done between 65 - 95 Fahrenheit.
Old 12-07-2017, 03:02 PM   #54
ststefan's Avatar
Trailer: 1979 Boler1700
Maple Ridge, B.C.
The tech sheet only said high heat resistance but no actual temps.
Old 12-07-2017, 04:59 PM   #55
Seaross's Avatar
Continued insulation.
Old 12-07-2017, 05:29 PM   #56
Gilles's Avatar
Quebec
Attachment 114449
Attachment 114450
Nice job Ross.
It is going well.
Gilles
Bigfoot 25B21RB.
Old 12-07-2017, 06:26 PM   #57
Seaross's Avatar
Thanks Gilles
Old 12-21-2017, 08:57 PM   #58
Seaross's Avatar
Connected led lighting todayClick image for larger version
ID:	114648Click image for larger version
Old 12-29-2017, 08:05 AM   #59
Saskatchewan
Ross - what a makeover! Lots of ideas for my reno of a 1300 Trillium recently acquired.
I am curious what you are going to place over the foil insulation or will it just be painted?
Cheers,
Murray
Kommander is offline   Reply With Quote
Old 12-29-2017, 04:17 PM   #60
Seaross's Avatar
I am installing Leatherette, but after testing Leatherette glued to foil, I could see the shape of air cells on Leatherette, so to fix that I am glueing 1/8 white felt and than will glue Leatherette. That’s the plan. Waiting for warmer weather to do gluing.
trillium
Trillium for sale kijjiji gatineau quebec Barrett family Referrals: Molded Fiberglass Trailers 0 07-31-2012 09:05 PM
'79 Trillium Jubilee 4500 $5350, Otter Lake Quebec GlenP Classified Archives 0 04-17-2009 10:38 PM
