trying to decide - Fiberglass RV
Old 11-16-2014, 07:50 AM   #1
Trailer: currently shopping
Louisiana
trying to decide
Hi,
I have a 4-cylinder subaru outback (2010) and was only looking at aluminum travel trailers until I saw the 15B Escape. It seems that I may be able to use my subaru to pull it. Does anybody have any experience or advice?
Nancy L is offline   Reply With Quote
Old 11-16-2014, 08:26 AM   #2
Bob Miller's Avatar
As is oft repeated, check your towing specifications in your vehicles owners manual and the Real World Trailer Weights list in the General Chat forum.
Unfortunately many Subaru's have lop sided towing vs hitch weight limits, meaning that you can't carry the amount of hitch weight you need for the maximum towing weight specified.
Also check here on the Escape forum where there is some discussion about the 15b getting a tad heavy on tongue weight, not a good thing for the Subaru.
15b tongue weight - Escape Trailer Owners Community
There is also another thread hereabouts concerning driveline wear in a Subaru that was seen as related to towing at or near those limits.
In short, you might want to think smaller.
BTW: What "Aluminum" trailers were you considering? I doubt if any weigh less than an FGRV
Old 11-16-2014, 08:36 AM   #3
Jon in AZ's Avatar
Nancy, welcome to the forum!
I owned a Subaru for 14 years and 205K miles ('93 Legacy wagon, great car!) but never towed anything bigger than a utility trailer. There have been a number of discussions on this forum about the suitability of Subarus as tow vehicles. Quite a few people use them to tow 13'ers, but they have some limitations when it comes to larger trailers.
First I'd read everything your owner's manual says about towing. There's a lot more to it than just the total weight of he trailer- things like tongue weight, brakes, hill climbing, etc.
Second, check out the thread http://www.fiberglassrv.com/forums/f...-43010-22.html. There is a very handy downloadable spreadsheet in post #297. Manufacturer's published dry weights are often deceptively low. These are actual, loaded-for-camping weights.
Third, you can search for the previous discussions by going to the blue task bar near the top of the screen under your log-in information. Click on "Search" and scroll all the way down to the Google site search at the bottom. Something like "Subaru towing" should give a number of hits.
Good luck with your research!
Old 11-16-2014, 08:57 AM   #4
I wouldn't tow a 15B with an Outback. Specs from the ETI website:
Old 11-16-2014, 10:01 AM   #5
Carol H's Avatar
I pulled a very lightly loaded 16' scamp trailer with an Outback that also had the 200lb tongue weight limit as such I would suggest that the 15' Escape is going to give you as much of a headache pulling a 15' as I got from towing the 16' scamp. Impossible to keep the tongue weight of it loaded to within Subaru Spec of 200lbs on the tongue and get a nice solid/safe tow. You will need to exceed Subaru's tongue weight spec. Subaru does not recommend the use of WDH on their all wheel drive system so thats not an option as a fix.
IMHO if your going to pull with the Outback best to stick to a 13' trailer and it will do just fine.
Old 11-16-2014, 10:12 AM   #6
Mike Magee's Avatar
Trailer: 93 Burro 17 ft
Oklahoma
Escape does not list a 13' on their website, but I believe they will build one for you on request. Of course, there are always the 13' Scamps and Casitas being built, and other brands pre-loved in 13'.
Carol is right, the 200 lb. hitch weight limit is the big problem.
Old 11-16-2014, 10:30 AM   #7
OneOleMan's Avatar
Trailer: Escape 17B Sold 5/2016
Nancy, only a couple months ago I was debating the same thing, I had a nice new 2014 Outback. Once I saw this on Escapes site under FAQ I knew my beloved Subie would die a quick death if I tried pulling either of the 15'ers:
Do I need a truck to pull an Escape?
No. On average, most Escape customers carry about 800lbs – 1,000lbs of cargo with them when they travel and add about 200lbs – 300lbs of options to their Escape Travel Trailer.
Therefore, the
• 15′ Escape, Plan A with a dry weight of 1,600lbs will travel fully loaded at about 2,600lbs.
• 15′ Escape, Plan B (Bathroom) with a dry weight of 1,750lbs will travel fully loaded at about 2,750lbs.
Pat
Life is Good
When "Escaping Reality" Sold 5/2016
2012 4Runner Ltd
OneOleMan is offline   Reply With Quote
Old 11-16-2014, 01:39 PM   #8
OneOleMan's Avatar
Mike, when I contacted ETI in September they told me they no longer offer the 13'er.
Pat
Life is Good
2012 4Runner Ltd
Old 11-16-2014, 03:38 PM   #9
Carol H's Avatar
Therefore, the
Those loaded weights clearly show the problem with pulling with an Outback and it 200lbs tongue limit...... impossible to keep it under 200lbs if you plan to use the 10- 12% tongue weight rule in order to get a stable/solid tow at highway speeds.
Old 11-16-2014, 04:15 PM   #10
Gilda's Avatar
Trailer: 2011 Scamp 13'
I tow a 13' Scamp with a 2008 Subaru Legacy Sedan with no problems (see my avatar and photos on my registry page). You can read my previous FGRV entries by running a seardh. I think my next car will be a Subaru Outback or Forester as they have higher ground clearance. California law says you may drive no more than 55 mph when towing. We follow this advice in other states as well.
The Gleeful Glamper
Gilda (Jill-da)
Gilda is offline   Reply With Quote
Old 11-16-2014, 05:29 PM   #11
OneOleMan's Avatar
Another consideration, Nancy, is where you plan to travel. If you come up to the PNW you’ll find there’s no such thing as flat, what we call hills others call mountains, you’re either going up-hill working the engine and transmission, or going down-hill working the brakes.
Pat
Life is Good
2012 4Runner Ltd
Old 11-16-2014, 07:38 PM   #12
Trailer: Currently Shopping"
Alabama
Smile
Originally Posted by Nancy L View Post
Hi,
I have a 17 ft Casita dry weight 2400 lb. I pull it with a chev. s10 4 cylinder 5 speed. I don't know the tongue weight off hand (I have a 2inch receiver hitch) and I use a load leveler that has sway bar control (friction type). It drops the truck 1 inch. I believe I can make another adjustment to where it will be zero drop. It really made a difference with it. With all of that it really pulls great. However, I don't go in the mountains with it. Am down south usually going to Gulf Shores from Birmingham.
bubblelover is offline   Reply With Quote
Old 11-16-2014, 08:26 PM   #13
Bob Miller's Avatar
I hope you are not suggesting your towing arrangement to others.
A 17' Casita will weigh about 3000 lbs going down the road and I believe that the 4 cylinder/5 speed S-10/Sonoma is rated to tow 2000 lbs, at least my 2003 model was, which is why I sold it to get a TV with a higher capacity so I could start looking for a 17' Bigfoot. The V6 with automatic is rated higher, but not the 4 cylinder/5 sp version
Old 11-16-2014, 08:58 PM   #14
Alabama
Smile
Hi,
I didn't mention earlier that with the 4 cyl. Chev s10, the truck in addition has a brake control and the trailer does have electric brakes which I keep hooked up. Sure does come in handy.
Old 11-17-2014, 07:48 AM   #15
Louisiana
it was a camplite, livin lite 14'. The subaru should pull it, my GVWT is 2700. But I really like the insulation, etc of the fiberglass trailers. Retired and wanting to travel the US. Have camped all my life, but always tent camped. Wanted to upgrade.
Old 11-17-2014, 07:55 AM   #16
Louisiana
Was looking at Camplite livin lite 13'. We are retired and want to see the US. I have camped all my life, but only tent camped. Thought we might upgrade. This is my first trailer. Didn't want to buy a new car, so was trying to find something that had a bathroom and we could pull with the subaru.
Thanks for all the advice, I have a lot to think about
Old 11-17-2014, 08:12 AM   #17
Nancy
I towed a S-13 front bath with my 2011 OB. I had elec. brakes on the trailer and a controller on the car. Most of my towing was flatland and we would get 21-22 MPG with the CVT. The trailer towed very nicely. I did try towing a S-16 but felt it was a little much for the car. If I find a S-13 FB with big bed for the right price I might move back to a Scamp.
The Camplite I think is wider and less aerodynamic than a Scamp. You may also may need to use towing mirror extensions with the Camplite.
Eddie
Old 11-17-2014, 08:16 AM   #18
Bob Miller's Avatar
Bummer.... the Camplite, at 2250 lbs barebones empty is even more than your Subaru can pull with 10% on the tongue. Down the road weight would most likely be right at it's GVW of 3000 lbs. A SCAMP 13' with a bath will likely also be well over your hitch weight limits, ours was close to 250 lbs.
Old 11-17-2014, 08:20 AM   #19
Alabama
I also like to camp and have had a pop up or two. But when I tried a Casita, I was hooked. Casita seems to have a good design for less wind resistance, quick setup, and don't have to worry about the roof leaking just to name a few.
Also I have an Amerigo that I "just had to have" and it is solid but could use some TLC. It could be used if I was the only one using. It's about 16 foot and no ac or bath. Will try to post pics of both later.
Old 11-17-2014, 10:40 AM   #20
Jim Bennett's Avatar
I know this may not work for the OP, or even other folks looking for trailers, but if at all possible you should first decide on what trailer would work best for your style. You could then figure out what tow vehicle would work best to pull it while servicing your other driving needs. This would be the ideal scenario in most cases.
Your moulded fiberglass trailer will outlast a few different tow vehicles, if you choose to keep it. Case in point, look at all the 40 year old FG trailers still in service today, with some (like one I have), getting remodelled into something better than they ever were.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
escape
Trying to decide on used Escape 17 or Casita 17 msu1966 General Chat 10 10-22-2014 04:38 PM
Trying To Decide How To Paint (Comments Please) glen coleman Care and Feeding of Molded Fiberglass Trailers 9 04-17-2010 08:42 PM
help me decide what trailer i need KellyT General Chat 11 04-21-2009 11:04 AM
Trying To Decide How To Paint (Comments Please) glen coleman Modifications, Alterations and Updates 0 01-01-1970 12:00 AM
