ventura 400B Hub Bearings - Fiberglass RV
Old 04-11-2021, 07:22 AM   #1
Trailer: Ventura
ON
I am rebulding a Monarch leisure products Venture 1986, I am confused with the bearing assembly their is not a bearing next to the hub on either wheel but everything else appears normal is this some sort of pressure fit for the inner race it is stainless and very smooth no sign of wear or tear in the bearing dept of the axle ? thereisalso a complete set of brakes on the trailer which have not been in use for years!
BILLMADILL is offline   Reply With Quote
Old 04-11-2021, 07:39 AM   #2
John in Michigan's Avatar
Trailer: 1979 Boler 1700
Hi Bill, welcome to the forum! Does your Ventura have a torsion axle. It might help if you post a couple of pics of your hub bearings. Also would be nice to see pics of your Ventura!
John in Michigan is online now   Reply With Quote
Old 04-11-2021, 05:40 PM   #3
Trailer: Ventura
ON
it is a torsion axle, I have to pull it apart again to get pictures of the assembly< but from the outside of the wheel there is a cotter pin , a nut , a washer a roller bearing then a cone then a grease seal. all were in good shape no grindings or loose bearings and it assembles tight1 also their is drums and brakes on the trailer that havent been active in years,(i am just leaving them alone) any info would be appreciated!
Old 04-11-2021, 06:01 PM   #4
Name: You can't call me Al
Massachusetts
If I'm imagining your setup, I think the inner bearing is still inside the hub you took off.
Take a peek at the diagram at this location:
https://www.familyhandyman.com/proje...heel-bearings/
The seal stays pressed into the hub, so the inner race, inner bearing and seal all stay "stuck" to the hub when you remove it.
See "Step 5" to remove the inner (Rear) bearing, race and seal.
AlanKilian is offline   Reply With Quote
Old 04-11-2021, 06:21 PM   #5
"Step 5" hammering on the bearing to get the seal out is only done by those that don't have and won't buy a seal puller to do it the right way.
Old 04-11-2021, 07:50 PM   #6
Massachusetts
That describes me for the last 50 years and 20 bearing replacements.
ventura
ventura 400B Hub Bearings BILLMADILL Towing, Hitching, Axles and Running Gear 1 04-17-2021 11:06 PM
Changing Axle Bearings on a '74 Ventura Dave Ventura Towing, Hitching, Axles and Running Gear 13 07-01-2013 11:04 PM
UHaul Wheel Bearings / Hub Thomas G. Towing, Hitching, Axles and Running Gear 14 12-14-2011 10:34 AM
Baby moon hub caps for '86 Scamp Wanted Gary Little Towing, Hitching, Axles and Running Gear 21 05-18-2011 09:48 PM
Checking hub and tire temperatures Legacy Posts Towing, Hitching, Axles and Running Gear 17 11-29-2002 08:04 AM
