Wall carpet (Casita) and raining into windows - Fiberglass RV
Old 05-17-2020, 06:07 AM   #1
Ohio
The biggest issue I have with Casita interior covering is when raining and windows are open water comes inside. Anyone know of a deflector that can be attached to fend off water.
diver3jp100 is offline   Reply With Quote
Old 05-17-2020, 06:20 AM   #2
Trailer: Casita 17 SD - sold - Lance 1475
Little House Customs sells window awnings.
https://littlehousecustoms.com/store.html#gen
jimiller5 is offline   Reply With Quote
Old 05-18-2020, 12:33 PM   #3
How about awnings?
Stephen_Albers is offline   Reply With Quote
Old 05-18-2020, 12:50 PM   #4
Trailer: Trails West
A roof vent fan that has a shroud that allows the vent to be open when it is raining is of benefit in such situations. You can still have fresh air without things getting wet.
Old 05-18-2020, 03:07 PM   #5
Trailer: 1978 Boler
Almonte, Ontario
I installed a marine solar-powered roof vent that is superb because it allows air to exit even when there is no sun to operate the fan. Mine has a storage battery so that it will operate 24/7 (sunlight required to recharge battery) but its plus is the fact that it’s marine and has a flange to keep out the rain.
The next post will show the box with info.
Nicolas is offline   Reply With Quote
Old 05-18-2020, 03:09 PM   #6
Trailer: 1978 Boler
Almonte, Ontario
The fan box. Not cheap but worth every penny to keep down the moisture during normal breathing plus allowing excess moisture to escape on rainy days.Click image for larger version
Old 05-18-2020, 07:52 PM   #7
Ohio
I meant the windows on the trailer not the top vent.
Old 05-18-2020, 08:49 PM   #8
Administrator
Mary F's Avatar
Trailer: 2015 Escape 21; formerly Casita 1999 17 ft Liberty Deluxe
I think they're saying if you have a top vent, you can keep the trailer windows closed when it's raining.
Once upon a time there was a great window vent product that several of us installed on at least one Casita window... but it's no longer made/available, as far as I know. Here's an older thread about them, along with a couple other ideas:
Window Rain Louvres
Mary F Fiberglass Rules!
FGRV Forum Custom Search
RV Life Network FAQ
Old 05-18-2020, 09:29 PM   #9
Trailer: 2013 Escape 19
This is one reason the old style jalousie windows are so treasured on the vintage trailers.
Without some kind of window awning, you will get rain coming in if the window is open on the slider type windows in a Casita (and many other brands of trailers). And if the rain comes with heavy wind, then an awning may not be very practical.
Old 05-19-2020, 06:22 AM   #10
Ohio
Rain Deflector
There are some great ideas presented. I am mostly interested in deflecting water coming off the roof. Tried finding those deflectors you see on cars with sunroofs and attaching with double sided tape but can't find one wide enough. The plexiglass one that was suggested seems to be the simplist solution. Also the one at the Elkhart place.
Old 05-19-2020, 06:30 AM   #11
Trailer: 1978 Boler
Almonte, Ontario
Window Rain Louvres
I love this redirect. Especially the one where the fellow used his ingenuity and fitted a marine window set of louvres. I hate to harp but sometimes the marine store is the place to visit (albeit not in a landlocked area). I’ve found an interesting assortment of items not carried in RV stores.
Old 05-19-2020, 06:39 AM   #12
Window Rain Louvres
I installed two window vents on my Casita back in 2015
When I purchased them from LHC they were the last ones Larry G had in stock
Worked great , why they were discontinued I can’t tell you
Old 05-19-2020, 07:21 AM   #13
Might want to consider this: https://www.rvgutters.com/
Old 05-19-2020, 08:42 AM   #14
Ohio
I have seen that product and it would keep most moisture and all the dirt out. May go with that if I can't find something that covers more. Thanks
Old 05-19-2020, 09:34 AM   #15
Trailer: Boler 1300
Hi John, I don't know if this might work for you but Vintage Trailer Supply has aluminum drip caps that come in a number of sizes if you're looking at just deflecting water flow off the roof.
bobdobqb is offline   Reply With Quote
Old 05-23-2020, 11:41 AM   #16
Trailer: casita
Connecticut
So easy. So cheap. So effective!
Plexiglass sheet. Masking tape across the top to hold it in place and to seal. A Small wood strut with velcro on the tips. Works very very well.
hts1190 is offline   Reply With Quote
Old 05-23-2020, 11:56 AM   #17
Ohio
Thanks
Old 05-23-2020, 12:48 PM   #18
tjs
Trailer: Award
We used these flexible, self-adhesive drip rails on our 1994 Award 23, and they did work fairly well. We now have purchased a 2011 Casita 17 SD and may try them again. Nice that they do not require drilling any holes in the side of the trailer.
tjs is offline   Reply With Quote
How should I clean wall and ceiling carpet? Stavig Care and Feeding of Molded Fiberglass Trailers 18 10-31-2020 08:11 AM
Any wall/ceiling carpet mods? Cover over carpet? mr_barbershop Modifications, Alterations and Updates 15 02-25-2019 09:11 AM
Replacing wall/ceiling carpet in Casita Spirit (not deluxe) Joanie R Modifications, Alterations and Updates 13 01-10-2019 06:59 PM
Casita interior wall carpet lshelly1061 Modifications, Alterations and Updates 9 10-15-2017 09:59 AM
Casita wall carpet alternative? Joe and Andrea C Modifications, Alterations and Updates 1 05-22-2012 01:52 PM
