Window Sealant - Fiberglass RV
Old 07-18-2020, 09:28 AM   #1
Trailer: Trillium 1300
Canada
Window Sealant
Hello,
I just purchased a 1976 Trillium 1300 Deluxe. After days of rain I discovered water in the storage area under the main bed and under the floor, and a bit of water dripping from the front foam padding, which bubbled out. I'm thinking the front window is the source and am going to start by sealing it. Can anyone recommend a good sealant?
Thank You in advance!
Wanderer2 is offline   Reply With Quote
Old 07-18-2020, 10:59 AM   #2
John in Michigan's Avatar
For leaks between the window frame and the fiberglass body, the long term fix (lasts 20+ years) is to remove the window, clean old sealant off the fiberglass body and the back of the window frame and re-seal/re-install with butyl tape (3/4" wide by 1/8" thick).
Any type of caulking is a temporary fix.
Trillium 4500 Journal
https://www.fiberglassrv.com/forums/f...nal-81345.html
Old 07-18-2020, 11:02 AM   #3
Also consider the possibility that water is getting in through the belly band. This is a common problem for Trilliums. The fix is documented in other threads.
Louver window frame Joints with Gray Sealant bog Care and Feeding of Molded Fiberglass Trailers 2 10-05-2017 01:35 AM
Trillium window sealant dleverton Modifications, Alterations and Updates 3 06-08-2015 01:13 PM
??Questions about front window over hitch?? Paint? Sealant? Coby Modifications, Alterations and Updates 9 04-22-2014 09:39 PM
window sealant jlbails Problem Solving | Owners Helping Owners 1 09-05-2012 08:32 AM
Old Style Window Sealant DannyH Problem Solving | Owners Helping Owners 9 01-21-2010 09:32 AM
