12v USB outlet - Page 2 - Fiberglass RV
Old 10-01-2017, 07:48 PM   #21
those usb ports have a dropping resistor to drop the voltage to 5v so you don't burn stuff up. Just run a like to any 12v line hook it up and off you go its no big deal. I put my switch on the battery itself so I can shut off 12v whenever I want. Single pole single throw switch will get it or an ordinary a/c off and on switch.
12v stuff is completely different from 110v
Old 10-01-2017, 07:52 PM   #22
ststefan's Avatar
Trailer: 1979 Boler1700
Maple Ridge, B.C.
Originally Posted by Buggeee View Post
Mine came with usb-C at both ends! They must like you more ststefan.
Somebody at the factory was having a bad Friday. lol My wife and I both got LG G5's. I also got an extra 2 cables each. All were normal.
Run 12V TV/monitor off of 12V outlet or via inverter? Rod Scher Problem Solving | Owners Helping Owners 24 06-19-2021 07:58 PM
Cigarette Lighter Socket with USB for 12v battery wysiwyg Electrical | Charging, Systems, Solar and Generators 8 08-22-2017 05:21 PM
Does adding multi-outlet to 12v outlet diminish output? Kudzu Asheville Electrical | Charging, Systems, Solar and Generators 8 05-08-2014 05:05 AM
Installing 12v outlet in 2013 Scamp Dsironi Electrical | Charging, Systems, Solar and Generators 10 05-02-2014 02:32 PM
On adding inside outlet for plugging in USB Infogypsy Modifications, Alterations and Updates 41 03-20-2014 10:17 AM
» Trailer Showcase
Big Foot
qds001
Boler
Naomi L.
