09-26-2017, 11:18 AM
Manuals.....
Manuals and specification sheets are your friend. Get the one(s) for those things you are planning on installing, read and understand them.
09-26-2017, 11:22 AM
I doubt a 4 dollar USB outlet will come with a manual or a spec...
09-26-2017, 11:27 AM
Trailer: Boler Voyageur 1977
Quebec
Originally Posted by jeroen
I've installed a simple 12V socket in which I connect whatever I need, being a drill charger, dvd player or USB charger. If I want to make sure I it's not draining power, I simply have to pull it a 1/4 inch.
I don't like built in USB chargers as they are usually low end and quite slow, especially compared to a quick charger. Also, I only have to buy one for the car and bring it in the trailer when needed. It's also future proof, if a new technology comes.
09-26-2017, 11:54 AM
Trailer: 1979 Boler B1300
New Hampshire
First of all, I wouldn't buy that particular USB outlet. It is definitely one of the cheap ones. You need to look for one that puts out a minimum total of 4.2 amps and will put the entire output to one outlet if only one thing is connected. This will allow your devices to rapid charge versus slow charging. Don't worry about blowing up something that only draws 1 amp. The outlet will supply whatever the device pulls and not any more.
The only way I can think of to find out if there is a draw without something plugged in would be to either do an internet search or get one and measure to see if there is a draw.
Regardless of whether you get a dedicated USB outlet or use a cigarette USB adapter, be sure the minimum amperage for a 2 port is 4.2 amps and it can supply all 4.2 amps to one outlet. The minimum amperage for a single should be 2.1 amps.
09-26-2017, 11:57 AM
Trailer: Trails West
09-26-2017, 12:13 PM
Trailer: Roamer 1
Smith Valley, Nevada
Aren't USB ports a standard 5 volts?
Might be best to install a cigarette lighter style socket and plug in a USB adapter. I know those sockets are big and old school, but there are a lot of things that use that format.
I use a 100 watt inverter in mine, for instance.
09-26-2017, 12:23 PM
The USB outlets are 12 volt to 5 volt DC to DC converters. They will use some power with nothing connected. When in use they dissapate more power than they provide and can get quite hot. I prefer using a 12 volt "lighter" socket and an external USB charger that can be unplugged when not in use. Easy to replace if it fails and it's in the open, not behind a wall. I installed something similar to this.
https://www.amazon.com/BANDC-Waterpr...12+volt+outlet
09-26-2017, 12:58 PM
What's the brand and model number?
I would almost be willing to bet I could find one.
09-26-2017, 05:52 PM
I'm rebuilding a Scamp and I'm currently designing the electrical system. Does anyone know if the cheapo 12v USB outlet draw power when no USB device is connected to it?
Yes they will. Not a lot but every little bit hurts when boondocking. The one I installed draws 15-18 mA even with no load.
But the real problem I found was the radio interference (RFI) caused by the cheap device. It obliterates my FM radio reception. (I also had a LED bulb that blocked a single TV channel).
For both those reasons I put it on a switch and leave the switch off when the charger is not needed. If I had it to do over again I would use 12 VDC (cigarette lighter) outlets only, and use a plug in a lighter type USB charger when needed. That way I would have had an extra 12 VDC outlet drawing no power at all when not in use, and a USB charger that I could use in the camper or in the car. In fact I have one that is combo 12 VDC or 120 VAC, with dual USB charging ports... very handy. I have found the USB chargers that plug into cigarette lighter supplies do not create as much RFI. YMMV.
And it true, these cheap devices (usually form China) rarely come with a spec sheet and if they do, I would not trust it anyway.
09-26-2017, 08:57 PM
Well the two USB outlets I installed in my trailer draw so little that my amp meter cannot read it (reads down to milliamps). Tried my digital multimeter, same thing, doesn't read anything.
So in my trailer they don't have a switch, they are powered all the time, and their draw when not is use is close to nil.
They recharge our devices nicely. Each have a 1A and a 2.1A port.
Motorcycle 1A / 2.1A Dual-USB Charger Adapter for Cellphones - Black - Free Shipping - DealExtreme
09-27-2017, 03:39 AM
Despite all the FCC compliance notices most consumer electronics is not well shielded leaving it quite susceptible to RFI (radio frequency interference). All these chargers are switching circuits that produce harmonics. Whether they interfere has more to do with the switching frequency than the cost. Different chargers produce different harmonics so some create problems while others do not. I suspect on your FM radio the noise enters through one of the IF stages though if the radio is plugged into the 12 supply, the noise could enter there. Try running on batteries to see. A bypass capacitor could cure the problem.
We enjoy listening to sports on the radio. Trying to listen to AM is a real challenge because of the much lower frequencies involved. Battery operation and radio placement both help.
The ARRL handbook used to have a pretty good section on RFI.
09-27-2017, 07:49 AM
When I measured the two plug in chargers I have, my measurements agree with Gordons. One was about 8 mA, the second about 12mA.
09-27-2017, 07:56 AM
I took the easy and future proof way and installed 4 additional 12 volt lighter outlets.
One IMPORTANT thing about 12vdc to USB adapters is it configured to "FAST CHARGE" the device. Doing research why my phone was "slow charging" I found out the difference.
A USB plug has 4 pins with the outer two being plus and minus.
In order to FAST CHARGE the adapter needs to have the middle two pins, normally for transmit and receive, shorted together. The device needing to be charged if it's capable of fast charging knows to fast charge. Devices that can't fast charge just ignore the two T&R pins.
So when looking for adapters you need to make sure it says fast charge or smart capable and they are not necessary more expensive.
I bought these and can verify they will fast charge capable devices.
Priced at TWO for $4.49 available in different colors shipped from California.
2Pcs Universal USB Car Charger Power Adapter Adapter for Smart Mobile Cell Phone | eBay
Joe
PS you don't get a data sheet or instructions either.
09-29-2017, 06:32 PM
Trailer: Playpac
OH
This is the answer.
Plus remember that all usb ports will be usb-C ports soon, which are shaped different. They are rolling out now on phones, making you buy new wall warts (charger cubes). Ask me how I know!!!
By the way, they are called wall warts because they slowly suck electricity out of your wall even when nothing is plugged into them, just like those USB ports. I like the idea of a cigarette lighter socket, what they now call a 12-volt power point, that you can plug in anything, anytime you want - like Raspy says
09-29-2017, 06:35 PM
Trailer: Playpac
OH
You will like them. And on that USB side you have the option of swapping that out for another 12 volt power point socket if you choose to do that later it just unscrews from that little paneling from behind and you can screw a different one in.
In case you're interested you can also find other little things to insert in those round faceplate holes instead of sockets or USB ports, like little tiny voltmeters that read out the current voltage in red, blue, green or any color you care to find. There's all kinds of stuff for those little 12-volt accessory panels
09-30-2017, 12:31 AM
Not to worry, there will be adapters around for a very long time
10-01-2017, 02:01 PM
Trailer: 1979 Boler1700
Maple Ridge, B.C.
Originally Posted by Buggeee
This is the answer.
the USB-C cables have the same usb end as all others but the phone end is different.
10-01-2017, 07:26 PM
Trailer: Playpac
OH
Mine came with usb-C at both ends! They must like you more ststefan.
