13' Casita Patriot deluxe 12V battery optional? - Fiberglass RV
Old 06-20-2020, 09:33 AM   #1
Trailer: no longer looking at Parkliner,04 Honda Odyssey
Hi! A friend of mine is fixing up an older Casita Patriot Deluxe 13'. She and her boys cannot find where the battery is located which typically, I think, would be mounted on the A frame near the hitch. Is there another possible location or is it possible that one would not necessarily need one if you just ran an extension cable from the plug on the tow vehicle to the camper and ran the tow vehicle while using electric in the camper? That is how I used to run my old Coleman popup but I only had to run the water pump and lights. Thanks in advance. Dave 🍻😎👵🏿
flaco is offline   Reply With Quote
Old 06-20-2020, 10:37 AM   #2
Trailer: 2008 Casita 17' SD
It's under the rear seat/berth cabinet on the right side. The 13 footers don't have the exterior battery access hatch. And, FWIW, it's a real pain to get to and to service it where they stuck it. That's why a lot of 13' owners have moved them out onto the "A" frames in front. It was a ridiculous place to install them IMO.
Old 06-21-2020, 09:19 AM   #3
WaltP's Avatar
Trailer: 2017 Escape 17B
SW Virginia
Actually I'm pretty sure it's on the left (driver) side but I agree with the rest.
And the 13s tend to be tongue light so moving the battery to the tongue shouldn't cause weight problems.
And BTW, there are inexpensive, waterproof battery boxes available to make that mod easier. They are available at Walmart among other places. The battery is a group 24 but moving it to the tongue opens up the possibility of upgrading to group 27 with a lot greater capacity, especially useful when boondocking.
Walt
Old 06-21-2020, 10:08 AM   #4
Hey you were right! Battery was right there. Pia to remove that big cover. Black wire goes to positive and green and white wires go to negative which seems counterintuitive to me. Is that correct?
Old 06-21-2020, 05:40 PM   #5
Trailer: Between RV's But Shopping
Mississippi
Wire Color Codes
Unfortunately, you are at the mercy of whoever
designed the wiring. Or perhaps what wire colors
they could spend the least amount of money on.
Black, white and green are typical of what you
normally see in AC house wiring.
You are probably used to a Red for positive and
Black for negative as used on your vehicle battery.
Some RV's may follow that color code.
Others can actually use Blue for positive and Black
for negative/ground.
Bottom Line ... When it comes to an RV .. You never know.
They can even swap colors at the fuse box.
Just always be aware of how "your RV" is wired when
adding or modifying the wiring. Purchase and learn to
use a voltmeter or multi-meter.
Arthur II is offline   Reply With Quote
Old 06-21-2020, 08:48 PM   #6
It is wired correctly according to ours. Seems wrong but when we got our Casita new from factory in 2007 that is how it was. We actually wrote on the door of the battery area I permanent marker so we wouldn't second guess it.
Old 06-21-2020, 08:56 PM   #7
When I was doing RV repairs I had a new motorhome that I had to correct some factory goof up electrical. From the dash to the rear of the unit the colors changed SEVEN (7) times! Even inside a wire loom. Talk about frustrating. That was only one of the flubs I saw. Dead short on trailer brakes, etc. There are times the RV techs really earn their money.
Bing M. is offline   Reply With Quote
Old 06-21-2020, 10:52 PM   #8
Mississippi
I know EXACTLY what you're talking about.
Worked on everything from pop-ups on up during my younger days.
[Decided not to say what I started to say here. LOL]
Old 06-22-2020, 03:08 AM   #9
member
Isle of Wight
That is correct.
It is a house, not a car.
Black is the "hot" wire in your house.....
WizWid is offline   Reply With Quote
Old 06-22-2020, 08:25 AM   #10
ZachO's Avatar
Trailer: Sasquatch
Montana
They're fairly standard. I mean I don't necessarily disagree with what others have said, but it's not like builders are throwing any random wire color at the battery connection. Yes it can be random inside the trailer, but the battery connections will be one of a few standard options, not just random colors. My camper is black and white. Unless someone actually screwed up, it helps if you can remember that white can never be positive according to electrical regulations. It's always has to be ground or neutral. That makes it easier to remember what black is.
All the same, I put a bit of red tape around the black, positive wire going to my battery to make sure it was obvious.
Old 06-22-2020, 12:10 PM   #11
WaltP's Avatar
SW Virginia
That's a common color coding on some household appliances like lamps: green ground, black hot, white neutral.
Walt
Old 09-24-2021, 09:27 PM   #12
billgo's Avatar
Wyoming
Photos
Does anyone have photos of how they secured a mount for the battery out on the tongue?
billgo is offline   Reply With Quote
battery, casita
NV | 1999 Burro 17' widebody with optional shower/toilet archeddie Classified Archives 10 01-13-2014 10:53 AM
Jacks for rear? On 13 scamp.? Needed or optional? Mcmarkrazz Towing, Hitching, Axles and Running Gear 16 08-29-2013 11:19 PM
1972 Boler - Canadian or American? Fridge optional? Melanie Problem Solving | Owners Helping Owners 3 06-27-2011 05:48 PM
Optional Location for A/C in new Scamp 13? melissab Problem Solving | Owners Helping Owners 7 12-11-2009 09:40 PM
(2008 Spring Event) ....clothing optional Doug Mager Ft. Langley B.C. Rallies 2 04-03-2008 01:13 PM
Copyright ©2000 - 2023, vBulletin Solutions Inc.
