02-19-2021, 03:35 PM
#21
last year at quartziete i saw a camper burn up! scarey stuff!
02-19-2021, 09:18 PM
#22
Trailer: wolf pup
IA
go to you tube search our latest mod
Originally Posted by Mike_L
Propane is a very flammable gas, that's why it makes a good fuel. Combustion under containment is an explosion. Propane tanks can leak but it's usually the hoses and fitting that are the problem. Even a small leak, over time can cause sufficient accumulation for an explosion to occur. That's why propane fixtures have to be ventilated. That's why propane must be stored outside or inside with appropriate ventilation. That's why many parking garages don't allow propane fueled vehicles entry.
A battery, or the electrical sparks they can produce, is an excellent ignition source. Consider a butane lighter. Sparks produced by a flint are used to ignite a stream of gas. Without the sparks the gas won't ignite. Without the gas, there is no fuel to burn. In either situation, no combustion so no problem.
The same works in this situation. Even the best gas installation can leak and those who use gas need to address this potential. Even the bast electrical installation can spark and this potential also needs to be addressed. In a situation where there is a potential for flammable gas leaks and an ignition source, the only effective way to address this hazard is to ensure the two potentials are physically separated to prevent the gas from accumulating to explosive levels in areas where sparking may occur. This is why propane tanks should never be stored in the same containment as a battery. Separate containments will allow any leaked gas to dissipate into the air and prevent its accumulation to explosive levels in areas where sparks may be produced.
Consider this perspective, if you store a propane bottle in the same containment as a battery, you are effectively building a home made bomb. It isn't a question of CAN this explode or WILL this explode but, rather WHEN will it explode and at what consequence?
if you go to you tube and search our latest mod. u will see someone doing just like me. not one comment about bomb except by me . yogi yogi. watch that video and u will see exactly what I'm doing
02-20-2021, 02:25 PM
#23
Trailer: 2010 Casita 17' SD
Originally Posted by yogavnture
i have ventilation. i heard that 2 6 volt batterys have a lot more juice than one 12 v..................my only concern is the tongue weight as the 6 volt batterys are heavy very heavy. i would say at least 65 lbs each.............
In general two batteries will get you more juice than one (there are exceptions). Difference is two 12s are hooked in parallel while two 6s are hooked in series. Some 6s are engineered to be more "deep cycle" than most 12s of relatively same size. They are all heavy.
02-20-2021, 04:46 PM
#24
Trailer: Trail Cruiser
Don't want to see anyone get hurt. Gas explosions can be catastrophic!
02-20-2021, 05:07 PM
#25
I use 12v batteries and I find I get more total run time using each battery individually than connecting them in parallel. I suspect the batteries equalize and that's the power loss process. Although they are the same batteries, they may be ageing differently?
Some folks say you get more power from two 6v batteries rather than two 12v batteries but I've never been able to figure out the math on that. The way I see it is if one 12v fails I have 1 battery to replace. If one 6v goes I have two batteries to replace.
I hadn't considered that the 6v may be more deep cycle and thus be able to suffer more abuse, interesting point!
02-20-2021, 09:20 PM
#26
Trailer: Little Guy Mini Max
Glenn, your patient endurance is to be commended.
02-20-2021, 09:57 PM
#27
Trailer: wolf pup
IA
me either that is why I'm posting I wonder if any one bothered to see the you tube video someone made of doing the same idea I have done. not one comment about explosion on it. and its at least a year old
02-20-2021, 09:59 PM
#28
Trailer: wolf pup
IA
yes that is why I'm going 6 volt route. because they can go lower than 12 discharge and still be ok. putting 12 v that low discharge over and over destroys them?
02-20-2021, 10:04 PM
#29
Trailer: wolf pup
IA
did u bother to go look at you tube video I mentioned above? it was posted over a year ago. they are doing same idea as mine. not one comment about explosion. and lots of people saying they gonna do it too. shouldn't they be warned??
02-20-2021, 10:06 PM
#30
Trailer: wolf pup
IA
go to you tube search ............................our latest mod............. first you go to you tube ...................then you go to search box. then you type in ...................our latest mod.......................u will see what I'm doing. not one mention of explosion
02-25-2021, 02:28 PM
#31
Trailer: 1980 Trillium 4500
Maybe no one there commented on it but several others here have tried to stress the safety aspect and are ignored
Is it just me or am I to lazy or incompentant to find this video!!!
Why don't you just post the url for this youtube video if it is a must see?
The reason accidents happen is because someone always thinks that they are the ones that can get away with it, and then they become the victim. You have two volatile gases, and a single spark can set them off, be it a spark from a wiring problem, a chain dragging on the ground, battery dicsonnect switch or static electricity. If it happens just one time you can never say it is safe again. Do you check your tank and hoses every time you disconnect them or ever for that matter for leaks. .
Here is a propane explosions, thought it was safe to transport in the back of their car, how much propane had to leak and not smell it in the car.KBOOM.
02-25-2021, 04:19 PM
#32
Trailer: wolf pup
IA
is it too much work to go to you tube and search our latest mods in the search bar. and then give your opinion? so much propane fear here but don't hear much about rv explosions. in gonna live ! not live in fear.
02-25-2021, 04:55 PM
#33
Trailer: wolf pup
IA
if you go to you tube and search our latest mod or our latest mods u willssee someone doing exactly like I'm doing. no recent responses on their video maybe they died in a propane explosion. just think before internet. people must have died every day from propane explosions
02-25-2021, 05:14 PM
#34
I suggest you busy yourself with creating passwords.
You could also work on punctuation and capitalization.
There are thousands of hours of video posted to YouTube every day.
02-25-2021, 10:41 PM
#35
Trailer: wolf pup
IA
ok glenn i do as you say...i didn't know that , thousands of hours of video on you tube posted every day. wow. that's good to know. thanks for all your help glenn
02-25-2021, 10:55 PM
#36
300 hours of video are uploaded to YouTube every minute.
02-25-2021, 11:12 PM
#37
Trailer: wolf pup
IA
GLENN you are watering down my thread
02-25-2021, 11:18 PM
#38
Trailer: wolf pup
IA
turner max adventures has a you tube . their video is our latest mod - dual propane. if you search that it will come up....good luck glenn you can do it!!!! its not that hard
02-25-2021, 11:26 PM
#39
The video will have a URL. It's in the header. You just copy and paste. Nobody will have to search.
02-26-2021, 08:01 AM
#40
Especially when search results on YT like any other platform will be different for different people depending on their previous searches, location, etc.
Algorithms... ;-)
