2 batterys and 2propane tanks together stored in tongue box - Page 3 - Fiberglass RV
Old 09-29-2021, 10:13 PM   #41
Trailer: 1980 Trillium 4500
Kalifornia High Desert
I didn't read the whole post but propane tanks have a safety relief valve that releases propane anytime the internal tank pressure gets above a set amount. The pressure in the tank goes up when heated even just the sun shining on it or the box that it is in. A spark from a lose wire, static electricity, or a switch can cause it to ignite and it goes BOOM and that's it. I have watched a propane tank vent itself for over 1 hour as it heated up more in the sun. Propane covers are opened on the bottom because propane is heavier that air and falls to the ground. Don't put any electrical in the same box as propane. The lead acid batteries in a box themselves have the same potential to explode because of the off gassing of when charging or heavy use. If you see corrosion on your battery terminals, that is caused by the off gassing and that is why battery boxes have vents also. One spark in either case can cause an explosion.
watch this on the tube
Not sure if you could call that a ghetto blaster or not.......
Sounds like you have a nice project you are doing.
1980 Trillium 4500 with front 1/2 bath, toilet, lavatory, 305watts solar, TriStar 45 MPPT controller, Trojan 1275 150amp battery. 2002 Chevy S-10 Crew Cab, 4.3, 4WD, Leer Shell
1977 Trillium 1300, front bunk beds. sold
2004 Damon Challenger 335F, fiberglass Class A, retirement home
ROBERT ONEILL is offline   Reply With Quote
Old 10-06-2021, 09:23 AM   #42
Joe MacDonald's Avatar
Trailer: 1981 Trillium 5500
guy's civility is a big plus, everyone has their own ideas, and while we may not like someone else's running them down is impolite. Everyone has a different comfort level with the things they do, if not we would all be clones.
think about this for a minute;
early cars were battery, because the battery companies had a successful campaign advertising about the safety of driving something that depended on explosions.
Fuel operated cars took over because of fear of electrical fires/explosions. and acid burns.
who was right? both, and both were also wrong, because they used their own agenda rather than science.
in a propane or natural gas powered vehicle, you have multiple possibilities of fuel leaks and sparks, yet they are perfectly legal
Hmmmmn.................................
Joe
Old 05-16-2022, 06:10 PM   #43
Markz's Avatar
I did it, but built in a firewall between the LP and batteries. Be sure to mount the regulator outside of your box. Click image for larger version
ID:	145945Click image for larger version
Markz is offline   Reply With Quote
Old 05-16-2022, 07:22 PM   #44
Trailer: Casita SD
^Very, very nice, Markz!
That's some superb workmanship!
JoelInTexas is offline   Reply With Quote
Old 05-30-2022, 10:41 PM   #45
Markz's Avatar
Thanks buddy
Old 05-31-2022, 06:40 AM   #46
ShelbyM's Avatar
Trailer: Casita SD
What, no Youtube video promotion? You are missing out on $! Seriously, that looks interesting enough for its own thread.
Old 05-31-2022, 07:26 AM   #47
Trailer: 2008 Casita 17' SD
Originally Posted by yogavnture View Post
did u bother to go look at you tube video I mentioned above? it was posted over a year ago. they are doing same idea as mine. not one comment about explosion. and lots of people saying they gonna do it too. shouldn't they be warned??
Just my opinion, fwiw, but I don't put any stock in most of anything posted on YouTube. The majority of YouTube vids are total crap, and many of them are either worthless, wrong and give useless, and at times dangerous, advice. Just because you can create and post a video is not any assurance that you are qualified or even know what you're talking about. Caveat Emptor.
Old 05-31-2022, 11:01 PM   #48
Markz's Avatar
Agreed, Both sides are sealed from the other when hatch is closed. LP side is vented heavily on bottom with a couple on top.
Additionally, the LP regulator is located outside of the box for venting far from the sealed LI batteries which do not vent gas. The batteries were. Chosen for their robustness. These are the type used in portable xray machines in hospitals, which means they are designed to be safe around oxygen, despite being in a separate sealed container. This is the thread covering the build.
https://www.fiberglassrv.com/forums/...ad.php?t=92750
Old 06-02-2022, 08:00 PM   #49
Markz's Avatar
Firewalls help to prevent fires.Click image for larger version
Old 06-02-2022, 10:29 PM   #50
John in Santa Cruz's Avatar
Mid Left Coast
yeah, LFP batteries are much safer than any form of lead-acid, and they aren't prone to fires like Li Ion batteries either.
Old 06-03-2022, 09:34 PM   #51
Markz's Avatar
True, the LiFePO4 batteries I used have the edge over lithium ion, both in terms of cycle life (they lasts 4-5x longer), and safety. This is a key advantage because lithium ion batteries can overheat and even catch fire, while LiFePO4 does not.
Combine that with isolating the electrical side from the flammable side, proper wiring, proper plumbing, insulation and sufficient venting means that your set-up should be reliable, long lasting and safe.
Old 06-04-2022, 05:29 AM   #52
Trailer: T@B
Nucamp put our dual 6 volt AGM’s under the bed in a sealed vented area. Just behind the axle so actually pivots a small amount of weight off the hitch. Hitch weight is a concern for us as we need to keep it under the 350 pound weight limit of our Tesla tow vehicle. Might be an option for you if you are concerned about hitch weight.
Cheers.
Travellers is offline   Reply With Quote
battery, propane
Two Batteries and Two Tanks Thee Jimbo Electrical | Charging, Systems, Solar and Generators 22 06-24-2022 11:07 PM
Meth Production and Propane Tanks Pete Dumbleton General Chat 8 06-06-2008 09:36 AM
Propane tanks AbenDeb General Chat 15 07-06-2007 12:32 PM
Propane Tanks for a Boler 13' Legacy Posts Problem Solving | Owners Helping Owners 11 07-18-2003 09:13 PM
Copyright ©2000 - 2023, vBulletin Solutions Inc.
