4500 trillium wiring - Fiberglass RV
Old 08-07-2013, 08:19 AM   #1
Trailer: Trillium 4500
Nova Scotia
Hi
Does anyone know how to hook up a 12 volt battery to a 4500 trillium trailer. the power supply has a 12 volt battery switch on it.
Thank you
Calvin Lee
patmarie1946 is offline   Reply With Quote
Old 08-07-2013, 01:45 PM   #2
Alex C's Avatar
Trailer: 1977 Trillium 4500
The switch is to bring in the converter which switches to 12v for lights and the 12v side of the 3-way frig. If your looking to rewire for a battery then I would also replace the old converter.
You can find a drawing for a trillium by searching this forum.
Good Luck
Alex C is offline   Reply With Quote
Old 08-07-2013, 03:37 PM   #3
Chris McVeigh's Avatar
Trailer: 1978 Trillium 4500
I took the easy route (for me) and wired a male coupler to a deep cycle battery. Of course you only need to hook up the white and black wires.
My converter still works fine and I usually just recharge my battery at home.
Chris McVeigh is offline   Reply With Quote
Old 08-17-2013, 10:12 AM   #4
Roy in TO's Avatar
I did similar to Chris,
1 two way plug from princess auto
2-Way 12 in. Trailer Harness | Princess Auto
cut it 1/2 and wired 1/2 to the battery with a fuse
Then connected the other 1/2 to a female 7 way plug
7-Way Vehicle End Trailer Connector | Princess Auto
You can then take this and connect your 7 way on the trailer to the battery. Also allows for quick connect of solar chargers to the battery.
On edit, I've never tried this while plugged in to 120V only use it when boondocking.
trillium
AB (Canada) - Trillium 4500 - 1978 - $4500 David Tilston Referrals: Molded Fiberglass Trailers 16 04-22-2013 01:07 PM
Trillium Wiring Alex C Electrical | Charging, Systems, Solar and Generators 42 08-10-2012 03:55 PM
OH | 1981 Trillium 1300 Trade for a Trillium 4500 Gene Griffin Classified Archives 13 03-06-2011 08:27 AM
1979 Trillium 4500 for sale -- C$5200 or US$4500 - SOLD jenniferm Classified Archives 8 07-14-2009 01:38 PM
