Why would you want a 7 pin connector? You would not want to connect a
solar panel to a tow vehicle and would not want to connect it to the trailer
battery via the 7 pin, too much voltage loss trying to charge through the converter.
The clips are made to connect directly to a
battery, positive and negative so the panel can charge the battery directly through the supplied controller. All you need is a connection to the battery from the solar panel.
If you do not want to use the supplied alligator clips then replace them with a Anderson style and a fused Anderson connector on the battery.
https://www.ebay.com/itm/23390727516...sAAOSw6cZhNDLD
https://www.ebay.com/itm/29436137525...e56551ba90dffd
That way it’s a simple plug and play process.
MC4 connectors are not meant to be connected/disconnected continuously as they are waterproof connections meant to be connected and left alone and require a tool to disconnect.
Another option, one I used, is to get a SAE/MC4 connector (10 foot) at the panel end and a SAE fused pigtail at the battery. This way is a simple connection from the panel to the battery. Further yet you could add a SAE port at the battery door, wired directly to the battery and plug the SAE panel end directly in to the port, a more permanent solution.
https://www.ebay.com/itm/29469427408...8626c9e5e935c0
https://www.ebay.com/itm/29479174308...c8657d6346e74a
https://www.ebay.com/itm/28463928608...af4f9cc5ca7630
The Renogy system is a great set up and the all inclusive package works well and is near foolproof.
There are many, easy solutions available.
