Adding a 12V outlet - Fiberglass RV
Old 04-06-2021, 11:01 AM   #1
Trailer: In the market
Adding a 12V outlet
I would like to add a new 12V outlet to my Casita using one of the empty slots on the DC distribution panel. My question is, where does the negative / return wire from the outlet go? It appears the positive goes into the distribution panel, but I am confused where the negative goes. I am (obviously) very green at how electrical works, so appreciate your help!
qkracken is offline   Reply With Quote
Old 04-06-2021, 11:28 AM   #2
Look for a negative buss bar. Or just attach it to the frame.
Old 04-06-2021, 02:12 PM   #3
AC0GV's Avatar
Wisconsin
Good time for a USB also
https://www.amazon.com/s?k=12+volt+a...f=nb_sb_noss_1
Old 04-07-2021, 11:20 AM   #4
Fredomatic's Avatar
Trailer: 1974 Perris Valley Pacer
Does your power distribution panel have multiple negative terminals? If so this is where you would connect. If not, you would need to wire in a splitter or bus bar. Note you have to stay within the power limits of your panel terminals so be careful with high powered items like electric water pots and electric blankets. If you intend to power an small Led light or phone you will be fine. Most likely your panel is rated to handle high wattage incandescent lamps. I added multiple usb outlets and 12 volt sockets inside my trailer. That said you must do your due diligence to make sure your not overloading your panel or wires.
Fredomatic is offline   Reply With Quote
Old 04-07-2021, 12:47 PM   #5
Civilguy's Avatar
Puget Sound, WA
The Casita A to Z Owner's Guide book has a wiring diagram that would help you first to understand what's already there, and secondly how you might best integrate new devices.
Casita Travel Trailers A-Z Owner's Guide
Old 04-07-2021, 03:09 PM   #6
WaltP's Avatar
Trailer: 2017 Escape 17B
SW Virginia
~ If anyone's posts here on the forum don't absolutely delight you,
please just keep that your own special secret! ~
Hey Mike. Getting a little touchy in your middle age?
Old 04-07-2021, 03:32 PM   #7
Thanks all! I do have the Casita A-Z book and have studied the wiring diagram.
I guess maybe the negative load for each device is just tied into the negative wire that runs around the entire Casita as opposed to individual negative terminals on the distribution panel. In which case, would the solution be to wire in a new negative bus bar to connect new devices to?
Old 04-07-2021, 04:43 PM   #8
Civilguy's Avatar
Puget Sound, WA
I think people should be able to post pretty much whatever they deem appropriate here.
Unfortunately, they often do.
Just sayin'.
Old 04-07-2021, 04:53 PM   #9
Civilguy's Avatar
Puget Sound, WA
You might run the risk of overloading a shared conductor if you just add another device to it. You'd have to look at the loads and see what the numbers tell you.
It seems this is a bit of a tough call to make without seeing what's going on. Is the bus full? Can a couple of conductors be doubled under one of the screws? Would splitting one or more of the existing wires with a different junction style located adjacent to the bus be acceptable? Do you have a place to add a bus? How many new devices are you thinking of?
Whatever you do, you'll want to have solid, reliable, vibration-resistant connections.
Run 12V TV/monitor off of 12V outlet or via inverter? Rod Scher Problem Solving | Owners Helping Owners 24 06-19-2021 07:58 PM
12v USB outlet jeroen Electrical | Charging, Systems, Solar and Generators 21 10-01-2017 07:52 PM
Exterior 12v outlet? herons Modifications, Alterations and Updates 13 09-01-2016 05:58 PM
Does adding multi-outlet to 12v outlet diminish output? Kudzu Asheville Electrical | Charging, Systems, Solar and Generators 8 05-08-2014 05:05 AM
Installing 12v outlet in 2013 Scamp Dsironi Electrical | Charging, Systems, Solar and Generators 10 05-02-2014 02:32 PM
