Ampere time - Fiberglass RV
Closed Thread
Old 05-10-2021, 02:10 PM   #1
Trailer: Casita liberty deluxe 17
Ampere time
Just ordered a 100 amp hr battery from this outfit. Does anyone have experience with them. Pricing is 540 delivered. Currently I have very minimal needs. There is a 0.8 amp constant. Water pump. C pap no heat. Furnace about twenty amps s day total.
tmaken2157 is offline
Old 05-10-2021, 03:07 PM   #2
Trailer: 2006 Scamp 19 Deluxe
Enchanted Mountains of Western New York State on the Amish Trail in Cattaraugus County!
who did you order from and what brand and type of battery?
I ordered from my local auto parts store. Note that I said local, not a national chain. They gave me best price!!
parmm is offline
Old 05-10-2021, 03:09 PM   #3
John in Michigan's Avatar
Trailer: 1979 Boler 1700
For LifePO4 batteries, discharging is OK below 32 degrees F, but NOT charging below 32 degrees F (will permanently damage the battery). According Will Prowse's review and bench test here:
Ampere Time batteries don't have low temp cutoff for charging. Apparently this is the only problem with this battery. To work around this problem, don't charge this battery below 32 degrees F ambient.
John in Michigan is offline
Old 05-10-2021, 04:53 PM   #4
David Tilston's Avatar
I suppose I could google it, but what is the reason to spend so much money on a 100 Ahr LiFePO4 battery? I am assuming that $540 is in US funds. That is like $700 in Canadian pesos! I had never heard of the 32F, (0C) charging limit. In Canada that could be quite a problem.
I was at Costco yesterday. They had the 240 Ahr golf cart batteries on for $175 CDN each. That gives a useful capacity of 120 Ahr for $350 CDN, or half the cost for more capacity. Mind you the size/weight is likely much higher with the golf cart batteries.
David Tilston is offline
Old 05-10-2021, 07:55 PM   #5
Advantages of LifePO4 batteries:
3000 to 5000 cycle battery
ability to use a much higher % of the battery capacity, virtually 100%
23 to 30 lbs for a 100 ah battery
very high charge and discharge rates
linear charge rate right up to 100% (instead of 80% with lead acid)
So you wind up with a very compact light weight battery set. EDIT: Also versatile and very long lasting. Suitable for high amp draws such as inverter loads.
Closed Thread
Long time snooper, first time poster - Hello! Joe & Cherie Hi, I am.... 5 03-20-2014 09:38 AM
a.c. ampere reqmt. for dometic rm2193 frig jondsw Problem Solving | Owners Helping Owners 1 10-04-2013 05:04 PM
Ice box part time, electric fridge part time? zoshia Problem Solving | Owners Helping Owners 8 05-17-2012 04:21 PM
