Boler Electrical Wiring 101 - Fiberglass RV
Old 09-12-2021, 02:23 PM   #1
Trailer: 1973 Boler
Saskatchewan
Hey all been a lurker on here for a while and this is my first post. We recently purchased a 13' 1973 Boler and I'm going to have to redo all the interior electrical as it's a mess and likely a safety hazard. I suspect I'm bringing up a topic that's been beat to death but I want to make sure I have it right before I start ordering parts so I apologize in advance.
It's pretty rare that we camp at an unserviced spot these days so my first instinct was just to go all AC Power and simply replace the old Bargman shore power inlet with a new 125v/30Amp RV inlet; maybe install an Inverter so I could use a battery as a back up. However, we are considering a long trip next year so serviced lots are not a guarantee and I've read Inverters suck the battery dry very fast.
Digging through the threads here it sounds like the most common recommendation is doing a dual AC/DC system with the AC going to the plugins and fridge (??) while lights, the water pump, roof vent fan etc. run off a set of DC circuits using a Progressive Dynamics 4000 Series Power Converter. Sounds like this product will also ensure the Batter is kept charged when plugged into Shore Power or Solar (not doing Solar yet but someday maybe). Anyway on to my stupid questions.
1) I'm assuming that the camper outlets are only available when your plugged into a serviced lot with the system? Pretty sure I'm right on this but wanted to double check so I can set family expectations accordingly lol
2) I'm thinking if I buy the following and some type 3, 10 gauged wire I have all I need but wanted to see if I'm missing something.
- 125v, 30A Inlet: https://www.amazon.ca/Swess-Power-Re...1476953&sr=8-5
- Progressive Dynamics Converter
https://www.amazon.ca/dp/B002XRU6H0/...v_ov_lig_pi_dp
- 12v Deep Cell Battery
https://www.amazon.ca/dp/B08VDW7MTT/...lig_pi_dp&th=1
ThatGuy306 is offline   Reply With Quote
Old 09-14-2021, 10:28 AM   #2
Joe MacDonald's Avatar
Trailer: 1981 Trillium 5500
A PD 4135 will give a 30a dc charge @ 12v, but only requires a 15a inlet, this means you can plug into any regular plug-in, just watch how many things in your trailer are on.
I have a 17 foot trillium, and that is all I have
really, there are 3 electrical systems in a trailer:
1) the 120v power that runs outlets, toaster, microwave, 12v converter etc.
2) the trailer 12v side for interior lights, 12v accessories like water pump, tongue jack, breakaway battery (if equipped), and power for fridge(if needed for controls)
3) the 12v wiring harness for the outside stuff- marker lights, brake lights, brakes.
The first two work together, the third is independent and is what the tow vehicle connects to.
Joe
Old 09-14-2021, 04:28 PM   #3
Trailer: 1973 Boler
Saskatchewan
Thanks Joe,
The previous owner did all 3rd wiring (vehicle wiring harness) then just stopped and left the rest in a ugly mess. I went ahead and ordered a PD4045 mini and the ShorePower Inlet. Found a really great youtube channel and am a lot more confident now. They focus a lot on Solar but cover the basics also;
https://www.youtube.com/c/EXPLORISTlife
Just need to decide on a AMG or Lithium Battery now think I'll go with one 100Ah Lithium for the time being.
Old 09-14-2021, 10:13 PM   #4
ststefan's Avatar
Trailer: 1979 Boler1700
Maple Ridge, B.C.
I'm assuming you have a 4 pin connector for the trailer. If you change to a 7 pin connector you could be charging the trailer battery while driving.
Old 09-14-2021, 11:08 PM   #5
Trailer: 1973 Boler
Saskatchewan
Yeah you would be correct it's just a 4 pin. I will have to look at moving to a 7 pin.
I'm considering a new frame with brakes so may wait until I make up my mind on that investment, which depends on how much I save for my assorted projects this winter.
Old 05-20-2025, 06:21 PM   #6
Hi Darcy, not sure if you are still around but I think my question might be similar to yours (but I likely have way less knowledge), I have purchased a '73 13 foot boler and the wiring looks to be a bit of a mess. Currently it looks like the 120V system is powering the outlet and the under cabinet light (we have no fridge or water pump, and intend to keep ti simple with the three interior lights and the single outlet), but i just tried installing new end of cabinet lights to the dead end wires that are in there that look like they should be connected to the circuit that runs the brake lights, but they are not working. I would like to replace everything and tidy it all up and have been searching and searching and can't find a straight answer.
Ideally... I would like to be able to replace the under cabinet flourescent with a 12v LED strip, and want to run 12V LED lights on the cabinet ends. I would like for this circuit (if possible) to be connected to the power coming in when I plug in at an electrical site.
Eventually, I would like to be able to power these lights and the outlet with a solar panel, I'm not sure if that changes how I should do things when trying to get the above set up acheived? Any advice would be super helpful!
jenjkrag is offline   Reply With Quote
boler, electrical
Towing 101 Legacy Posts Towing, Hitching, Axles and Running Gear 22 05-08-2003 07:44 PM
Any TTs on Highway 101? Heads up! Legacy Posts Jokes, Stories & Tall Tales 5 03-11-2003 04:16 PM
Electricity 101 Legacy Posts Modifications, Alterations and Updates 11 11-09-2002 01:53 PM
Parking 101 General Chat 0 01-01-1970 12:00 AM
