Casita electrical - Fiberglass RV
Old 04-29-2020, 01:40 PM   #1
West Virginia
Casita electrical
I pray that all are safe.
I have a 2019 Casita Spirit Deluxe and want to turn the electric off. I can unplug the shore power, but how to disconnect the battery without disconnecting the battery wires. I think this is done in the 2020 with a disconnect switch. Is it feasible to consider installing this on my 2019?
Stay safe,
Ralph
RLJR is offline   Reply With Quote
Old 04-29-2020, 02:10 PM   #2
AC0GV's Avatar
Wisconsin
Yes
Stay safe,
Ralph
Install it in the negative.
Old 04-29-2020, 02:12 PM   #3
West Virginia
Thanks for the quick reply.
Where do I get the switch?
Old 04-29-2020, 02:22 PM   #4
AC0GV's Avatar
Wisconsin
Auto parts stores
Almost any place that sells auto parts. My last one came from the local farm and barn store, but amazon has them also. You do not need a high current switch to run a car starter, I used the cheapest that I could find (mounted in a dry location).
https://www.fleetfarm.com/detail/wir...606&bn=wirthco
Disconnnect the negative from the battery and connect it to the switch and then run a jumper from the other switch bolt to the negative battery connection.
Old 04-29-2020, 03:34 PM   #5
Trailer: Casita 17 SD - sold - Lance 1475
Little House Customs sells them.
https://littlehousecustoms.com/store.html#elec
jimiller5 is offline   Reply With Quote
Old 04-30-2020, 05:15 AM   #6
Why the negative?
Rick In Mn is offline   Reply With Quote
Old 04-30-2020, 06:45 AM   #7
Trailer: 2008 Casita 17 SD
This what I installed in my 2008 17 SD. It's on the POS (+) wire. I've always put cut-off switches on the positive side.
Old 04-30-2020, 07:05 AM   #8
AC0GV's Avatar
Wisconsin
Why the -
Originally Posted by Rick In Mn View Post
Why the negative?
Now you started something. The safest way is to install the disconnect to whichever terminal is grounded. Typically the negative. The connections are not well insulated and can easily be shorted to the frame with tools etc. My disconnect was on the negative on my old one, currently I just pull the fuse. However, some racing rules require the positive.
But this debate could go on for pages.
Old 04-30-2020, 11:11 AM   #9
It doesn't make any difference which side negative or positive you break the circuit.
Old 04-30-2020, 01:27 PM   #10
AC0GV's Avatar
Wisconsin
Read the distructions
h
https://www.wirthco.com/battery-doct...sistant-switch
For use in Line on the Negative Battery Cable
Old 05-01-2020, 12:05 PM   #11
As Byron said, either way it is simply just there to break the circuit path to the battery. Really what difference is there in whether it is in the positive or negative wire? I know what Wirthco says, but I don't really feel that it is necessary to only put it in the negative line. FWIW, its also says you might get cancer if you even use it in California. But then, everything sold in California will give you cancer. It's amazing that there's still anyone alive in Cal.
Old 05-04-2020, 07:45 PM   #12
Coastie's Avatar
Trailer: Currently Shopping
The switches Casita uses aren't expensive, but if you'd like the one I just removed from our late model 2019 SD 17 I'll give it to you if you pay for the shipping cost. This is what they are using My guess is that shipping to you will cost at least $6.99 that the switch costs at Harbor Freight. I upgraded to a better switch that is less of a snag hazard in the location Casita installs them (base of the rear most side dinette bench). If you want me to send you mine PM me.
Semper Paratus
USCG, Disabled
2019 Casita SD 17
Coastie is offline   Reply With Quote
Old 05-06-2020, 12:52 PM   #13
Trailer: scamp
Indiana
Stay safe,
Ralph
What I have for mine is a fuse right in the battery box. Got one of the ones that lights up when blown. If I want to disconnect it, I simply pull the fuse. That way I have protection form a short and a shut off for when I actually need it.
computerspook is offline   Reply With Quote
Old 05-06-2020, 01:48 PM   #14
Doctor Harold's Avatar
Trailer: 1975 Scamp, 13-foot
Redding, California
One old-school thought about putting the cut-out switch in the negative side comes from car-theft prevention. With negative-ground cars that have points, when some amateur tries to hot wire your car they will jump a wire from a positive source to the coil's positive terminal, and jump to the starter solenoid to crank, but if the negative circuit is the one broken, the fool will stand shaking his head not understanding what's wrong. If the cut-out controls all current the car won't crank, but if you have a cut-out for everything except the starter current, the car will crank, but won't start.
Not really relevant to FGRVs, but hopefully interesting.
You cannot have a proud and chivalrous spirit if your conduct is mean and paltry; for whatever a man's actions are, such must be his spirit. --Demosthenes
Doctor Harold is offline   Reply With Quote
Old 05-06-2020, 02:04 PM   #15
What about the type of disconnect switch that mounts on a round battery post and has the knob on it that you back off a turn or so to disconnect the battery. I have it on one of my farm tractors. I've seen them at Walmart and online at Amazon. On two trucks and one other tractor I have the good Cole Hersee heavy duty switches.
Old 05-06-2020, 04:26 PM   #16
Trailer: casita
Connecticut
FWIW, its also says you might get cancer if you even use it in California. But then, everything sold in California will give you cancer. It's amazing that there's still anyone alive in Cal.[/QUOTE]
GREAT comment. I concur.
hts1190 is offline   Reply With Quote
Old 05-06-2020, 04:32 PM   #17
GREAT comment. I concur.[/QUOTE]
You'd rather be in Flint?
Old 05-07-2020, 11:21 PM   #18
Trailer: 1980 Trillium 4500, 2004 Damon 34' Challenge Fiberglass motorhome,
Kalifornia, Michigan, any other place we stop.
As I just posted in another post go to Harbor Freight and get this switch for $6.99.
See Post # 11
https://www.fiberglassrv.com/forums/...m_medium=email
https://www.harborfreight.com/Batter...tch-63425.html
ROBERT ONEILL is offline   Reply With Quote
casita, electrical
Casita Towing Electrical Requirements Dougey Problem Solving | Owners Helping Owners 10 08-31-2019 08:29 AM
2016 17' Casita Electrical Issue Becky B Problem Solving | Owners Helping Owners 13 03-07-2019 07:42 PM
Electrical-can't get my electrical heater started. robertmarchiony Problem Solving | Owners Helping Owners 6 09-08-2017 06:11 AM
Casita electrical question astronomer Modifications, Alterations and Updates 17 10-19-2012 02:38 PM
Casita- Electrical Mods Aids10 Modifications, Alterations and Updates 3 03-25-2012 11:31 AM
» Trailer Showcase
Lily
Wpuvy
Burro
Alan C.
