Casita inside light switch works sometimes - Fiberglass RV
Old 11-02-2023, 07:11 AM   #1
jgilliam1955's Avatar
Trailer: Casita Liberty
Virginia
My Casita light just inside the door started acting up. I have to play with the slide switch to get it to come.
Is this an easy fix to replace the unit?
Been with my sweetheart since 1969
2015 Chevy Colorado & 2019 Casita owner
If I won the award for laziness, I would send somebody to pick it up for me.
jgilliam1955 is offline   Reply With Quote
Old 11-02-2023, 07:17 AM   #2
Try turning it on and off a bunch
justa25thTA is offline   Reply With Quote
Old 11-02-2023, 07:36 AM   #3
Virginia
THANKS!!! That worked!
Old 11-03-2023, 04:11 AM   #4
C&G in FL's Avatar
Trailer: 2015 Escape 5.0TA
Probably caused by oxidized contacts. There is a product named DeoxIt, somewhat pricy, but extremely effective. A little can be sprayed into switches through open cracks and then the switch is repeatedly operated as suggested. I have found the results to be more reliable and longer lasting than just repeatedly operating the switch. It can also be used on umbilical cord contacts or shore power cord contacts.
Old 11-03-2023, 05:15 AM   #5
Virginia
Thanks! I will try it.
Old 11-03-2023, 08:32 AM   #6
Trailer: Casita Liberty Deluxe
LA
Thanks for the tip on Deoxit, in "industry" working on electronics we had several products we referred to as "technician in a can" because so many intermittent switch problems could be resolved with contact cleaner/lubricants.
I've had good luck restoring switches on the Casita with CRC 2-26 which is readily available at Home Depot in miniature cans.
daveandalice is offline   Reply With Quote
Old 11-03-2023, 10:14 AM   #7
jerrybob's Avatar
Trailer: casita
Had the same problem with the outside light on our Casita.....a quick spray of WD40 and rocking the switch back and forth many times cleared the problem. Good luck.
jerrybob is offline   Reply With Quote
Old 11-08-2023, 03:59 PM   #8
Trailer: scamp
Indiana
Fixed a lot of stuff this way. The one I use is called DeoxIt5 No Idea what the 5 stands for.
computerspook is offline   Reply With Quote
Old 11-08-2023, 07:54 PM   #9
Mike Magee's Avatar
Trailer: 93 Burro 17 ft
I think it indicates a 5% solution of Deoxit in solvent. Good stuff. I have some tiny tubes (with integrated applicator brushes) of Deoxit Red and Deoxit Gold that I have used for several years on flashlight contacts and such. I just ordered a can of the spray because one of the exterior light switches on my Escape is acting up from corrosion & whatnot. Think I might try it on a couple of wall switches in the house, too (although they might simply have worn out).
casita, light
Is it ok to mount a battery isolation (cut off) switch inside the trai Curtis F. Problem Solving | Owners Helping Owners 8 07-05-2007 06:46 PM
Annoying and sometimes Frightening wild Critters! Gina D. General Chat 24 05-09-2007 06:31 PM
Why Computer's Sometimes Crash Donna D. Jokes, Stories & Tall Tales 4 01-13-2006 10:17 PM
Inside switch for outdoor light? Legacy Posts Modifications, Alterations and Updates 2 11-11-2002 09:00 AM
