Casita Interior Lights - Fiberglass RV
Old 06-29-2022, 09:26 PM   #1
Montana
I lost the interior light in the hallway and the outside light. Have checked fuses and bulbs. THese are OK. Next step?
Montana Mac is offline   Reply With Quote
Old 06-30-2022, 12:40 AM   #2
Trailer: Casita SD
Which Casita model?
JoelInTexas is offline   Reply With Quote
Old 06-30-2022, 09:57 AM   #3
Montana
Originally Posted by JoelInTexas View Post
Which Casita model?
It's a 17 Spirit Deluxe 2006
Old 07-01-2022, 12:32 AM   #4
Trailer: Casita SD
On my 2021 Spirit Deluxe, those two fixtures are at the very end of a wiring string that runs under the carpeting on the wall behind the microwave oven compartment.
Casita uses "quick-splices" to connect the fixture wires to the DC supply wire - and these splices aren't always installed correctly.
So, I would suggest poking around to see where your splices are (you may be able to feel them through the carpet), and confirming that they're still making good connections.
If you have to cut through the carpet to access them, use some contact cement to close up the cuts after you're finished.
Old 07-01-2022, 09:18 AM   #5
Montana
Thanks for that suggestion. I had no idea where to even think about beginning. THat would make sense that they are on the end of the run and both out with compromised splice.
Old 07-01-2022, 12:36 PM   #6
Trailer: Casita SD
While you're in there, you might consider reconnecting your outdoor fixture so that it's controlled by a switch mounted somewhere inside - Allows you to turn on that light at night without leaving the security of your trailer.
I installed mine (a miniature toggle switch) on the right side of the range hood, immediately above the rear sleeping area - Don't even need to get out of bed to turn it on.
Old 07-14-2022, 12:45 PM   #7
LarryB.'s Avatar
Trailer: SOLD: Casita17' Spirit Deluxe (aka: Tweaker's Casita)
Southwest Ohio
On my 2007 Casita Spirit Deluxe, the "hallway" light and the external light (by the steps) are on the same 15 amp fuse. If I remember correctly it is fuse #2.
LarryB. is offline   Reply With Quote
casita, light, lights
Tail lights, marker lights, reflectors jeroen Modifications, Alterations and Updates 15 10-30-2017 06:06 PM
Trillium Original tail lights/marker lights to LED Cassie Trill Modifications, Alterations and Updates 13 07-23-2016 09:04 AM
Brake Lights, Turn signal lights, marker lights, oh my! glamourpets Problem Solving | Owners Helping Owners 19 01-03-2013 10:10 AM
LED trailer lights / Non LED lights on tow vehicle Kevin K General Chat 20 11-24-2010 12:05 PM
LED lights in Original light sockets - tail lights Cam A Modifications, Alterations and Updates 75 02-15-2009 11:54 PM
