Your 2017 should have a multi-stage smart charger, but you can check with Scamp to be sure. You also need to determine if your trailer has any parasitic loads in the form of circuit boards that are always on. Electronic
fridge controls, battery monitor, and hardwired safety detectors are possible culprits.
In the absence of parasitic loads, once a month for a few hours or overnight should be enough to keep your battery topped off. The self-discharge rate is probably about 3-5% per month. Parasitic loads will increase that rate and require more frequent charging.
If you leave your trailer power cable continuously connected, the cord port is a potential entry point for mice and insects. You need to seal it tightly or swap it out for a marine-style detachable cord.
For us, because our trailer was not stored conveniently near an electric plug, it was easier to remove the battery and leave it on a smart charger, which we run once a month.
There's a lot to learn when it comes to RV deep cycle batteries. I'd recommend searching "how to care for RV battery" and read a few articles. Even something as basic as determining your battery's state of charge is not so simple. I learned a few things the hard way, and I am still learning.
Best wishes becoming friends with this vital component!
