Chassis/frame grounding on 12 volt syst on a Scamp 13í deluxe - Fiberglass RV
Old 03-07-2021, 02:05 PM   #1
Arkansas
For some reason I can’t get a ohmmeter reading from the trailer 7pin ground to the frame of the trailer. Looked at the wiring from 12v batt and wiring (blk & wht) go directly to the out put 12v on the connverter. According to the installation manual on the pd9130 connverter it shows a frame lug on the back of the connverter to the frame. Looked for it and the lug is empty. Scamp wiring diagram shows brake ground to the rest of 12v grounds. But in checking the brakes they are grounded to the frame. If that is the case I should should see a ohmmeter reading from the frame to the brake thru the magnets to the blue(brake) on the 7pin. To summarize, I feel the chassis should be connected somewhere to the 12v circuit. Talked to a guy from scamp and he said the do-not bond the connverter to the frame because of circulating ground currents. I am aware of those but it does not seem to be worrisome in this application. Got a FCC radio tel license but does not help me out.
Joseph in Ark is offline   Reply With Quote
Old 03-07-2021, 04:48 PM   #2
Try from the frame to the white wire on the connector.
Old 03-08-2021, 11:16 AM   #3
Arkansas
Tried that first. Also took a reading from the battery pin on the 7pin to the negative side of the battery and got 12.62v on that but same setup on the frames shows a 1volt drop to 11.67 volts.
Old 03-08-2021, 11:24 AM   #4
Massachusetts
(I'm sure you know this already, but...)
The 12 Volt AC-to-DC converter is just for powering your lights and appliances when plugged in to campsite power.
All those devices have a +12 Volt wire and a Ground wire connected between them and the converter, so there's no need to connect the converter to the chassis/frame at all.
Now, how to help you diagnose your connection problem?
HERE'S a wiring diagram that shows the brakes connected between Blue and White, but not connected to the chassis.
Maybe someone rewired your brakes to the frame and someone else removed the harness-to-frame connection?
Anyway, I would like my brakes to not rely on the frame. Maybe just rewire them to the common ground wire.
AlanKilian is offline   Reply With Quote
Old 03-08-2021, 11:33 AM   #5
The White wire in the camper harness must be attached to the chassis.
They get rusty and detach. Find where it should be attached, clean frame to bare metal, reattach with a lock washer that will dig in and me, I coat it with Liquid Tape.
Old 03-08-2021, 11:38 AM   #6
Raz
Raz's Avatar
Vermont
Based on previous posts, it is my understanding that Scamp uses the frame as the return path for the brakes. With a 1 volt drop between +12 and the frame I'm guessing your ball is providing the connection. My solution would be to run a wire from the frame connection to the negative battery terminal. Also, watch any frame connection for corrosion issues, especially if they used self tapping screws.
Old 03-08-2021, 11:45 AM   #7
Trailer: 2018, 21ft escapeó 2019 Ram 1500 Laramie
It seems that FG trailer manufacturers like to attach wires to the frame with cheap self drilling screws . The screws corrode or they become loose leading to a poor connection .I remove the self drilling screws , tap the holes for 10/32 machine screws , clean the frame , reattached the wire / lug using SS screws and lock washers then coat the area with liquid tape
On my Scamp , Casita and Escape they used the frame as the return conductor
( DC -) for the trailer brakes so a good connection is necessary
Old 03-08-2021, 12:56 PM   #8
For some reason I canít get a ohmmeter reading from the trailer 7pin ground to the frame of the trailer. Looked at the wiring from 12v batt and wiring (blk & wht) go directly to the out put 12v on the connverter. According to the installation manual on the pd9130 connverter it shows a frame lug on the back of the connverter to the frame. Looked for it and the lug is empty. Scamp wiring diagram shows brake ground to the rest of 12v grounds. But in checking the brakes they are grounded to the frame. If that is the case I should should see a ohmmeter reading from the frame to the brake thru the magnets to the blue(brake) on the 7pin. To summarize, I feel the chassis should be connected somewhere to the 12v circuit. Talked to a guy from scamp and he said the do-not bond the connverter to the frame because of circulating ground currents. I am aware of those but it does not seem to be worrisome in this application. Got a FCC radio tel license but does not help me out.
Check the converter connections.
Old 03-08-2021, 01:01 PM   #9
( DC ) for the trailer brakes so a good connection is necessary
WRONG... The green wire on power cor connects to safety ground. the when the converter os connected to power the negative side is connected to the frame of the trailer. The white wire and the green wire are connected to ground (earth) at the shore power breaker box. This prevents shocks if should touch the frame and earth at the same time and there ie current leakage someplace in the system.
Old 03-08-2021, 03:43 PM   #10
I donít understand what your objection is ?
The brakes on my trailer has one wire connected to the 12VDC supply from the brake controller and the other wire is connected to the frame
The 120 VAC equipment ground ( Green) in the power cord is connected to the equipment ground bus in the converter panel and is bonded to the metal chassis of the trailer .
My point was that plated self drilling screws make a poor connection because they have a tendency to rust / loosen
If the frame of my trailer is not bonded to the negative from the battery then how are my brakes able to function ?
Not going to argue with you
Old 03-08-2021, 04:24 PM   #11
Im thinking Byron Kinnaman might have been under your camper one day when you were not there. After all, he is an electrical engineer.
Old 03-09-2021, 08:41 PM   #12
Arkansas
Chassis/frame bonded to ground on12v.
[QUOTE=Joseph in Ark;807611]For some reason I canít get a ohmmeter reading from the trailer 7pin ground to the frame of the trailer. Looked at the wiring from 12v batt and wiring (blk & wht) go directly to the out put 12v on the connverter. According to the installation manual on the pd9130 connverter it shows a frame lug on the back of the connverter to the frame. Looked for it and the lug is empty. Scamp wiring diagram shows brake ground to the rest of 12v grounds. But in checking the brakes they are grounded to the frame. If that is the case I should should see a ohmmeter reading from the frame to the brake thru the magnets to the blue(brake) on the 7pin. To summarize, I feel the chassis should be connected somewhere to the 12v circuit. Talked to a guy from scamp and he said the do-not bond the connverter to the frame because of circulating ground currents. I am aware of those but it does not seem to be worrisome in this application. Got a FCC radio tel license but does not help me (Quote)
Old 03-09-2021, 08:42 PM   #13
Arkansas
[QUOTE=Joseph in Ark;807833]
Old 03-09-2021, 09:13 PM   #14
Arkansas
Found the problem. The ground bar on the ac/dc distribution panel,back has 3wires inside trailer where the converter is located. One is a 10 gauge to the 7 pin,one I 12the white and goes to the ground bar mentioned above and a large(bigger than 10 gauge) and bare goes from ground bar to the same location as the as the other 2. It goes thru the glas wheel well. When out side and found a double lug block. From what I can see is a 10 gauge wire in one of them and what appears to be a 12 gauge solid. To tired to follow up. May be tomorrow. Buy the way the screw holding the double lug ground blocks to the frame was rusted off and block was and just laying against the rust on the frame.
Old 03-09-2021, 09:17 PM   #15
Massachusetts
If you want to have trailer brakes all the time in the future, you can decide to rewire them and not connect them to the frame, but rather, wire them to the trailer connector directly with a reliable wire.
Old 03-09-2021, 09:31 PM   #16
Arkansas
Thanks for all the ideas every one of you
Old 03-10-2021, 08:26 AM   #17
Exactly what I did.. I will not reply on a electrical connection to the frame for my brakes. I did leave the frame connection in place, but also ran parallel ground wire from the brakes to a junction box where the 7 pin wires are connected (another upgrade from Scamps wire nuts). Unless a rat chews the wire it is a very dependable method. And even then the frame connection might still be in place if it has not corroded away.
I'm pretty sure he was thinking of the 120 VAC wiring. Why I dont know since this thread is all about the 12 VDC side.
Old 03-11-2021, 10:01 AM   #18
Trailer: 1978 Burro
EE or E
Electrician and Electrical Engineer both start with an E.
DuaneQ is offline   Reply With Quote
Old 03-11-2021, 10:32 AM   #19
The Answer: I questioned a manufacture of RV converters and here is the answer.
Hi Darwin,
You ground your A/C circuits to the ground bus bar, which grounds to the frame.
You ground your D/C circuits to the frame or battery negative.
Do not ground your D/C circuits to the A/C ground bus bar, as there is only enough locations for your A/C circuits.
Old 03-11-2021, 01:41 PM   #20
One has a degree and the other one knows what he is doing.
Adding a front table to a Scamp using the Lagun Swiveling Cockpit Table Mounting Syst gordon2 Modifications, Alterations and Updates 26 08-30-2020 11:12 AM
Grounding 120v to the frame... KyMoonshine Electrical | Charging, Systems, Solar and Generators 11 01-15-2015 02:28 AM
Frame Ground/Chassis Wire multi-task Electrical | Charging, Systems, Solar and Generators 35 04-28-2013 04:44 PM
Chassis Frame Weld -Help it's coming undone! Maggie S. Problem Solving | Owners Helping Owners 6 07-29-2012 08:57 PM
Recommendations? TV, DVD, CD syst. for Scamp 5th David Craig Care and Feeding of Molded Fiberglass Trailers 19 01-14-2008 11:32 PM
