Electrical Help - Fiberglass RV
Old 08-08-2022, 10:49 PM   #1
Electrical Help
Hi all!
I have a 2010 Scamp and initially thought we had a dead battery. Bought a new battery and still no power. But power works when plugged into our home. Where should I start first?
Thanks for the help
scamp360 is offline   Reply With Quote
Old 08-08-2022, 11:54 PM   #2
AC0GV's Avatar
Wisconsin
At the battery
Originally Posted by scamp360 View Post
Hi all!
Thanks for the help
Using a test light or meter check the voltage at the battery and work your way to the fuse panel. The fuse or its holder in the battery box is a common failure point. Your book may have a wiring diagram in the back. Some years had a fuse under the bunks just inside the front also.
Old 08-10-2022, 09:34 PM   #3
This is extremely helpful, thanks for taking the time to explain!
Old 08-10-2022, 10:39 PM   #4
and after you've discovered you hooked up the battery wrong, check the 30 amp fuse in the converter.
CalCop is offline   Reply With Quote
Old 08-17-2022, 10:22 AM   #5
I missed the part where they said they hooked up the battery wrong.
Bayou Belle is offline   Reply With Quote
Old 08-17-2022, 01:01 PM   #6
Trailer: 1979 Layton 22 ft / 2004 Ram-Cummins 2500 2wd
It is easy to make that mistake, because main battery connections are generally RED (+), BLACK (-), unlike most everything else you'll encounter.
Re-check the Main Battery connections . then look for a blown Main Fuse in the stated locations.
Lloyd (aka Santa) Coltman is offline   Reply With Quote
electrical
Electrical-can't get my electrical heater started. robertmarchiony Problem Solving | Owners Helping Owners 6 09-08-2017 06:11 AM
electrical Help for burro camper trophymuley Problem Solving | Owners Helping Owners 4 07-25-2011 12:38 AM
Help! Electrical Gremlin Aboard cyndi H Problem Solving | Owners Helping Owners 2 07-22-2009 06:48 PM
Electrical help needed Pam Garlow Problem Solving | Owners Helping Owners 6 11-20-2007 01:35 PM
Electrical problem - Help! scott fraser Problem Solving | Owners Helping Owners 2 08-07-2007 06:03 PM
