If you plan to include shore power connection capability, you could go this route:
- Progressive Dynamics PD4135 with LifePO4
battery charging feature
- 100 amp hour LifePO4 batteries are becoming fairly economical (less than $500).
- Running a 110v
fridge for two days without shore power is NOT feasible unless you include a half dozen 100 amp hour LifePO4 batteries. Running an efficient 12vdc compressor fridge for two days without shore power IS feasible with two 100 amp hour LifePO4 batteries. An efficient 12vdc compressor fridge will use less than 60 amp hours of electricity per 24 hours.
- Using an inverter with 110v outlets for appliances will be questionable / very limited with the above setup. You will be on a tight power budget.
