I have the
Trillium Sidekick 2014. It has a Zamp Solar ZS-6AW Solar Panel/Controller package. The solar controller is located behind the Progressive Dynamics Controller.
Zamp Solar ZS-6AW
The Zamp Solar ZS-6AW is a 3 Stage 6 Amp PWM Waterproof Solar Charge Controller for use in 12 volt systems with gel, AGM, wet and calcium Batteries. Unit is potted in Epoxy Resin rendering the internal components waterproof and weatherproof. Built-in regulator prevents battery overcharge, discharge and damage. Connect to the battery permanently to keep the battery fully charged when used with a
solar panel. This process also reduces water loss in wet type deep cycle batteries.
Key Features:
* Low power and cost effective – ideal for remote locations
* 0 to 100 % Pulse Width Modulation (PWM) Charging Technology
* 100% SOLID STATE: All power switching is done with MOSFET
* Surface Mount
* Suitable for Solar Panels up to 100 Watts
Technical Specifications:
* Battery System Voltage: 12V
* Max. PV Open Circuit Voltage: 26V
* Max. PV Short Circuit Current: 6A
* PWM Setpoint: 14.3V (Sealed), 14.8V (Wet)
* Min. Operating Voltage: 3V
* Rated Charging Current: 6A
* Max. Load Current (1 min.): 8A
* Max Charging Current (5 min.): 8A
* Rated Load Current: 6A
* Ambient Temperature Range: -40 - +60C
* Relative Humidity: 100%
* Approvals: EN 55022 / EN 61000 / FCC Part 15 Subpart B Class B
* Dimensions (mm): 97 L x 46 W X 20.5 H
Weight: 103g
