LOL yes I did install it myself. (I'm a DC electrician so it should be good. I usually work with -54 volts DC so +12 is no prob).
I think I may have figured it out. I'm thinking the voltage really is higher than with the old batteries. I was using 3 recycled 12 volt 8 ah batteries in parallel. They were originally just to power my
LED lights and charge a phone here and there so it was fine. When the furnace kicked on the draw would drop the voltage below 12 volts regardless of charge state. That was the catalyst for the lithium upgrade. Plus I got my eye on a compressor
fridge now.
When I get home from work I'm going to swap the
battery back to the lead acid and see what happens. With the fan whirring and the obvious extra suction in the cabinet cavity causing negative pressure at my burners this makes the most sense to me. I was reading another post on here from a ways back someone installed a DC-DC converter between power and their suburban furnace to quiet it down. He dropped it to 10.5 volts and said it halved the noise. That may be the best solution for me too. 16,000 BTU heats up my
boler in about 4 minutes so I'm really not concerned with tamping it down a little. Will report back later today.
