Home Depot Solar - Fiberglass RV
Old 01-21-2022, 06:38 PM   #1
Trailer: 2008 17 ft Casita Spirit Deluxe
Home Depot Solar
I did a search, but it doesn’t look like anybody has asked it this Home Depot system would be as good a deal as it looks:
https://www.homedepot.com/p/NATURE-P...3000/311140816
Ruth C. is offline   Reply With Quote
Old 01-21-2022, 10:11 PM   #2
Go talk to someone at Home Depot that knows about these things. One thing about it is if you buy one and don't like it you can take it back. Best to buy locally for that reason.
Old 01-21-2022, 10:58 PM   #3
Trailer: Bigfoot 17G
The same kit seems available on eBay all the time for $107.70.
And HD also has the same kit with a 300-W inverter for $11 more = $99.88 BUT, it is out of stock at the moment.
bobblangley is offline   Reply With Quote
Old 01-22-2022, 05:55 AM   #4
Trailer: Boler 13 ft / Casita FD
I am no expert on the subject but I do know there is a difference between a Policristaline and a monocristaline panel.
I was told by a solar panel installer the Mono is better.
Why I can not answer this but I am sure others can.
Old 01-22-2022, 06:48 AM   #5
T2S
Trailer: Escape
PADUCAH
Mono panels are more efficient so a physically smaller panel can generate similar output. Since space is limited that is generally prefferred for permanent installs (maybe less so for portable panels). I have friends that have used grape solar panels from Home Depot and been happy. Generally the charger included in kits is the weak link. If you find a great deal on a kit then I would still recommend replacing the charger with a better quality one. The kit in the link doesn't look like a good deal to me, but I haven't been following prices lately.
T2S is offline   Reply With Quote
Old 01-22-2022, 03:29 PM   #6
sokhapkin's Avatar
SW Florida
The only difference is in the panel size. Monocrystaline panels are slightly smaller than poly at the same rated wattage. If the size works to you, then buy either one.
Sergey
Old 01-22-2022, 03:32 PM   #7
sokhapkin's Avatar
SW Florida
Big box home improvement stores are good for everyday items. Novelties like solar panels/charge controllers etc are extremely overpriced there.
Sergey
Old 01-23-2022, 01:40 AM   #8
Steve Outlaw's Avatar
Trailer: Oliver
This is incorrect. Monocrystalline panels have a higher conversion efficiency than polycrystalline panels, which means they produce more kilowatt-hours of electricity. If you want to install a solar system but your space is limited, monocrystalline panels will be more productive per square foot. Also, they have a lower temperature coefficient, making them more efficient in the heat of the sun and about a 10% greater expected lifespan. However, they are the more expensive of the two types. The charge controller does not say, but is most likely a PWM as opposed to an MPPT and will be another weak link in this system.
Personally, I'd pass on this system.
Good luck with finding that person.
Steve and Tali - Dogs: Reacher and Rocky and our beloved Storm, Maggie and Lucy (waiting at the Rainbow Bridge)
2022 Silverado High Country 3500HD Diesel 4x4
Steve Outlaw is offline   Reply With Quote
Old 01-24-2022, 10:32 AM   #9
Larry C Hanson's Avatar
Solar Info
Hello,
A great place to further your understanding of solar electric systems is here:
https://www.solar-electric.com/learning-center
Uncle Larry
Old 02-11-2022, 08:00 AM   #10
I have three Grape Solar panels on the roof of my 16' Scamp. The small controllers that typically come with these is worthless.
I paid about $75 each at a Home Depot surplus store new in the box. These are usually mis-hipped rejected orders etc.
I have mine hooked up in series with an MPPT controller after using a couple of the cheaper controllers.
I looked and did not find these for that price on the website.
Looks like the prices have gone up to $110 +.
My Grape Solar 100 watt panels have held up well in several years service and 10's of thousand miles.
Old 02-12-2022, 06:30 PM   #11
David B.'s Avatar
Trailer: Former 13’Scamp, now Snoozy
The size difference is significant. I use one Renogy monocrystaline 160 watt panel on our roof, vs 3 of the HF poly panels.
solar
RV Electrical adaptors at Home Depot Timber Wolf Electrical | Charging, Systems, Solar and Generators 2 04-02-2016 09:31 AM
BOLT DEPOT.com Bill Nolen Problem Solving | Owners Helping Owners 1 03-04-2016 08:51 PM
Bus Depot awning - weather tested Jack Walter Modifications, Alterations and Updates 7 10-16-2015 02:34 PM
Bus Depot awning Tom Trostel Modifications, Alterations and Updates 8 07-11-2010 07:24 PM
Copyright ©2000 - 2023, vBulletin Solutions Inc.
