Honda Generators Run Time - Fiberglass RV
Old 11-27-2020, 09:56 AM   #1
Trailer: '15 17' LD Casita and '17 Tahoe LT
Just curious if you have a run time engine meter on you little Honda and how many hours it has on it. The one I bought in early 2002 is about to turn over 2,000 hrs. Beginning to puff a little smoke on start up but does not burn oil between oil changes and still purrs right along. My second one has a little problem with the choke lever jiggling around and causes it to surge if I don't put a little piece of tape to keep it in place after start up. It has clocked 800 hrs. Sometimes I connect them together when needed.
dmad1 is offline   Reply With Quote
Old 11-27-2020, 01:56 PM   #2
AC0GV's Avatar
Wisconsin
Simplified Honda Hour meter
Originally Posted by dmad1 View Post
Just curious if you have a run time engine meter on you little Honda and how many hours it has on it. The one I bought in early 2002 is about to turn over 2,000 hrs. It has clocked 800 hrs. Sometimes I connect them together when needed.
Limited use, but it has one.
Old 11-28-2020, 12:47 PM   #3
If you were driving a car at 60 mph that would be 120,000 miles in 2000 hours so for a little air cooled engine that is pretty good. The puffing of blue smoke may be your valve guide seals being worn.
Lee
Captleemo is offline   Reply With Quote
Old 12-22-2020, 06:21 PM   #4
North Dakota
Generator
I agree, the puff of smoke is more than likely the valve stem seals. By not changing the seals, can cause carbon build up in the top end of the engine. Maybe causing shorter engine life. I read on another forum. subject being Honda eu2000i. It was claimed by a poster that his eu2000i had over 3500 hours on it and still running well. He had installed a hour meter when brand new.
If you are using two eu2000i hooked together to run your a/c. You might want to look at a soft start for you a/c. I have on my a/c and the single Honda eu2000i will start the a/c no problem even on eco throttle. No brown, out just a smooth start on the ac compressor
hghsl is offline   Reply With Quote
generator
What can I run and not run on my home electricity? GregandTeresa Electrical | Charging, Systems, Solar and Generators 21 06-18-2016 06:16 AM
Honda Generators CarolMarie Problem Solving | Owners Helping Owners 15 08-29-2012 09:50 AM
speaking of Honda Generators lloyd cicetti General Chat 2 04-09-2009 04:15 PM
alternatives to honda and yamaha generators lloyd cicetti General Chat 21 03-11-2009 05:50 AM
HONDA GENERATORS - Special Offer For FiberglassRV Members Bigfoot Mike Problem Solving | Owners Helping Owners 9 02-23-2009 09:48 PM
Copyright ©2000 - 2023, vBulletin Solutions Inc.
