How know when Scamp battery is getting low? - Fiberglass RV
Old 02-01-2014, 10:20 AM   #1
Dsironi's Avatar
Trailer: 2013 Scamp 16'
Wisconsin
I have read numerous references about. Battery power and charging methods. We have always used full electric hookups. Later this month we'll head south and may camp in N P without electric. How will I know if my battery is running low? Measure voltage across the poles? What will be a low indicator -1 v.. -2v. ??
Dsironi is offline   Reply With Quote
Old 02-01-2014, 11:44 AM   #2
sokhapkin's Avatar
SW Florida
Normal battery voltage is 12-13v. Voltage of discharged battery falls to 10v and below.
Sergey
Old 02-01-2014, 12:03 PM   #3
David,
You can buy a simple tester that reads battery voltage that plugs into cigarette lighter outlet. Or if you have a stand alone meter you could measure voltage at the battery.
Fully charged you would read 12.7+ volts, and down around 50% discharged 12.2v.
It is best for battery health to stay above 50% state of charge.
If you do have to discharge lower, say 20%, you want to re-charge as soon as possible to avoid damaging the battery.
Russ
Old 02-01-2014, 12:17 PM   #4
OneTim's Avatar
Trailer: Escape
Rhode Island
I suggest you read http://manmrk.net/tutorials/RV/phred/battery.html
If you have a 12 volt outlet in your Scamp you can buy an inexpensive digital voltmeter that just plugs in. It will give you a rough idea of your battery status.
The working range will be from about 12.6 down to about 12.3 volts.
OneTim is offline   Reply With Quote
Old 02-01-2014, 01:58 PM   #5
kdhanso's Avatar
Tester
I use something like this
INNOVA 3721 Battery and Charging System Monitor : Amazon.com : Automotive
Ken
kdhanso is offline   Reply With Quote
Old 02-01-2014, 04:34 PM   #6
Trailer: Class A Motorhome
Not mentioned is that draining your battery below 12.2 volts will also significantly shorten the life of your battery.
You didn't mention how old your battery is and/or how you will be charging it both when pluigged in as well as when under way.
If you are using the original, pre about 2012 Scamp converter/charger you can get almost anything from undercharged to boiled. That said, also check the battery voltage when you are plugged in and let us know that number as well. As a hint, if it's not at least 13.2 volts when charging, you may never get a full charge.
Don't forget to check your water level add distilled water if low, then charge again.
Bottom line, Batteries are a very fickle item
Old 02-01-2014, 04:52 PM   #7
The Minimalist's Avatar
Louisiana
Try this site. The 12volt Side of Life (Part 1)
Also has a battery condition chart you can download and print. I keep a laminated copy next to my battery meter.
Clif
Old 02-01-2014, 05:11 PM   #8
kdhanso's Avatar
I keep this in my phone
Name:   ImageUploadedByFiberglass RV1391296284.810108.jpg
Ken
Old 02-01-2014, 08:23 PM   #9
Dsironi's Avatar
Wisconsin
Thanks for the good posts. FYI, My Scamp is 2013, 16'. 24EV deep cycle silver alloy battery. I've charged it with my tow alternator and from the AC when connected. While sitting under covers this Wisconsin winter, I removed the battery to my cool basement. The cells appeared at good levels of water. I put my son's BMW charger on the battery today. I do not yet own a voltmeter that measures tents of a volt. My multipurpose analogue meter showed just under 12 v this morning (under may be a calibration issue.) the charger was putting out 13-15 v when charging. I disconnected it after three hours. After disconnecting the battery showed 13v, and now 3 hours later it shows 12.2- 12.4v(?). I'll check it again tomorrow.
For the future, I will see about wiring a 12v outlet near the power panel and acquire one of the meters some of you recommend.
I appreciate your guidance.
David
Old 02-01-2014, 08:31 PM   #10
Briantb's Avatar
Trailer: 2015 Scamp 13 Front Washroom, Van Camper
New Brunswick
Another caution.. Don't leave the battery on your concrete basements floor
Briantb is offline   Reply With Quote
Old 02-01-2014, 10:13 PM   #11
David B.'s Avatar
Attachment 67977
I have that very same chart that I printed out and taped it to the inside of a door next to the plug-in volt meter.
Dave & Paula
Old 02-02-2014, 08:50 AM   #12
Rick n's Avatar
Trailer: Beachcomber TM15
Get yourself a battery dicharge indicator (BDI)
Here's a link to what you're looking for.
Curtis Instruments | Battery Discharge Indicators and Combination Gauges
If you contact your local forklift dealers parts department they will be able to help you out with the BDI and how to wire it into your camper battery circuit.
Rick.
Rick n is offline   Reply With Quote
Old 02-02-2014, 09:05 AM   #13
Rick n's Avatar
When charging a battery......
David
A battery must be fully charged in order for it to gas and mix the electrolyte (charging will take 6 or more hours depending on the battery capacity and current rate of charge) this must must be done in a well ventilated area because the by product of charging a battery is hydrogen gas emissions( very explosive) so do not smoke or have any spark or flame or ignition source around the charging battery. A properly rated deep cycle charger with an automatic shut off should be used, also someone mentioned about not leaving the battery on the concrete floor, this is great advice because if you leave the battery on the concrete floor it will go to ground and discharge over time to the point of no return.
Rick.
Old 02-02-2014, 09:14 AM   #14
C&G in FL's Avatar
Trailer: 2015 Escape 5.0TA
Any battery left over time will discharge.
What a long strange trip it’s been!
Old 02-02-2014, 09:24 AM   #15
Rick n's Avatar
Yes that is true
However a properly maintained battery can last many years.
Old 02-02-2014, 09:43 AM   #16
C&G in FL's Avatar
Yes, it is true that proper maintenance will enhance battery life. Chargers with a desulfation ability help, as premature battery death often results from sulfur build-up in the cells. But storing one on a concrete floor will have no adverse effect on the battery. Today's batteries are made with a non porous hard plastic shell rather than a hard rubber based case. Many years ago concrete may have been a no-no, but no longer true, now an urban myth.
Old 02-02-2014, 10:22 AM   #17
Go to: snopes.com: Do Cement Floors Ruin Car Batteries?
to read more.
Old 02-02-2014, 10:51 AM   #18
Briantb's Avatar
New Brunswick
Interesting.. Tks
Old 02-02-2014, 11:09 AM   #19
Rick n's Avatar
Sounds sound.....
If stored in a garage in a colder northern climate I would still avoid the concrete floor and opt for a non conductive well ventilated shelf because the potential for freezing the battery would be greater in my opinion.
Rick.
Old 02-02-2014, 07:17 PM   #20
Mike Magee's Avatar
Trailer: 93 Burro 17 ft
Never saw these before. Had to order one! I do have a 12v socket in my trailer.
battery, scamp
Low Voltage battery cut off???!!! dylanear Electrical | Charging, Systems, Solar and Generators 30 06-19-2012 09:47 PM
Low Throne Problem Larry C Hanson Modifications, Alterations and Updates 7 06-25-2009 08:27 PM
Low carbon footprint tow vehicle Dana T General Chat 0 05-16-2009 03:57 PM
OK, I am getting old? And I don't know it? Gina D. General Chat 49 06-04-2006 01:28 AM
I know, more battery questions!! Legacy Posts Electrical | Charging, Systems, Solar and Generators 8 07-02-2003 04:49 AM
