How to reverse polarity in running/ tail lights? - Page 2 - Fiberglass RV
Old 05-13-2018, 06:43 AM   #21
John in Michigan's Avatar
Trailer: 1979 Boler 1700
correction
To the OP, CORRECTION from my previous comment: If your LED side marker lights NEVER light up (but the original incandescent side markers worked), suspect polarity is reversed, and you need to swap the wires at each side marker fixture.
Old 05-13-2018, 12:57 PM   #22
floyd's Avatar
Originally Posted by Eggcentric View Post
PS the fact that shore power ground is connected to the frame is of no consequence to the 12V system.
It is in fact consequential since the shore power cord is connected to the converter chassis and the converter chassis is subsequently attached to the frame, a connection which serves no real purpose.
If the Scamp to which I referred earlier had no converter chassis ground attachment to the frame, there would be no 12V reading between the house battery and the frame.
House wiring converters are provided with both fused positive power supplies and negative terminal blocks.
Using them is the best and most reliable approach to house wiring.
House wiring aside...
It is both common and acceptable practice to use the frame for ground for both DOT wiring and brakes. That of course does not necessarily make it the best practice, especially with a fiberglass RV.
light, lights, tail lights
LED Tail Turn Signal Running Lights for 13' Boler HawkBoler72 Modifications, Alterations and Updates 10 05-27-2016 09:14 PM
LED's require correct polarity Paul O. Electrical | Charging, Systems, Solar and Generators 22 07-10-2015 06:56 AM
LED lights in Original light sockets - tail lights Cam A Modifications, Alterations and Updates 75 02-15-2009 11:54 PM
Reverse lights dont work on the back of trailer McClure Problem Solving | Owners Helping Owners 4 08-22-2006 06:46 AM
LED Reverse lights - inside trailer ? Kurt in BC Modifications, Alterations and Updates 3 04-18-2006 04:09 PM
