04-05-2021, 01:49 PM
Wisconsin
I need soft start help
I am installing a soft start unit in a 2017 Scamp and after watching several videos and placing the order, none of the videos were like mine. Any one know of a video for the install on a newer 13,500 Dometic? Pictured is the only place I see that it will fit. EVERYTHING is foam covered and I do not want to disturb the foam.
04-05-2021, 02:31 PM
Name: You can't call me Al
Trailer: 1977 Scamp 13'
Massachusetts
That looks like an OK place to install it.
Maybe flip it over so you can see the LEDs.
04-05-2021, 03:20 PM
Wisconsin
Too bad...
... to install a well designed nice looking product "bacK out" so the nice clear cover and label will not show, but will do.
TNX qc0gv
04-05-2021, 04:31 PM
Wisconsin
No micro air video for a newer Scamp??
i have spent the past hour looking at videos done by people that to not know the difference between the compressor and the capacitor. And none are for the newer Dometic 13,500 BTU that I have. Time to re-invent the wheel??
Any one know of a video?0
04-05-2021, 04:44 PM
Trailer: Escape
New Mexico
Did you watch my u-tube video installing an easy start to my Dometic 11,000 btu AC?
I cannot imagine there would be much of a different position for attaching the thing.
https://youtu.be/I9AmXfKwrjo
04-05-2021, 05:10 PM
Wisconsin
Thanks, I'll watch it.
Yes, your video has the correct number of wires, and note that the loose wire nut was a crimp connector. Scamp used lots of wire nuts in the past and many came loose. Thanks and back to the roof!
I have almost no room, but this site may have the answer also.
http://www.micro-air.com/support-doc...ily_RV_ACs.pdf
04-05-2021, 07:38 PM
Wisconsin
Hot side hot and the cold side cold
That URL led to fantastic information. I had ordered the install kit with the soft start, and while I had most of the parts left over, I was glad I had it. It came with one grommet and I would have liked three. I seldom follow instructions and mounted it different than the instructions. I have watched adhesives fail many times and the zip ties were white and they NEVER last long term, so I wanted stainless steel bolts. Below is the mounting picture in the instructions. Best I can tell, my unit requires no learning cycle, but I will investigate that more. It was quite an easy install, but watch out for the cover, it is FRAGILE to say the least. I cracked it just lifting it off. I may put a 1” strip of fiber glass mesh around the inside when I run out of things to do.
04-06-2021, 02:26 PM
Trailer: '15 17' LD Casita and '17 Tahoe LT
My understanding is that those made since about '15 come with a hard start already part of the unit. Might be worth checking around.
04-06-2021, 02:42 PM
Trailer: 2017 Escape 17B
SW Virginia
A bit late now, but Lowes has stainless steel zip ties that come in very handy for permanent installations.
Walt
04-06-2021, 02:46 PM
Wisconsin
Good question
Mine shows a locked rotor amps of 68 and I have still been running it on a 2200 Honda. The company lists it for the Brisk air II. I have not hooked my meter to it and do not know if my meter will even show the LRA. At one time I think Scamp said the "new" A/C could be run on a 2000 honda and then for some reason they quit saying that. The big problem is playing with the thermostat and starting the compressor against pressure. Hands off the t stat I think it would be OK.
04-06-2021, 02:48 PM
Wisconsin
I forgot about them
Walt
It will help others that follow. Note also that LOWES is not alowd in my area, John Menard lives just down the road.
TNX
04-06-2021, 03:17 PM
SW Virginia
But of course they are also available on Amazon.
Walt
04-07-2021, 12:16 PM
Wisconsin
Kill A Watt meter
I got out the Kill a Watt meter and I think it is to slow to get a start reading. It shows less than 14 amps to start and that would be very low. Run current was under 13 amps and fan only was under 4 amps. Idle current on the Scamp was under 0.3 amps.
04-07-2021, 01:24 PM
I would think the only way you are going to measure locked rotator amps is with an oscilloscope since the amount of time it exists is measure in milliseconds.
04-10-2021, 11:34 AM
find an electrician or HVAC tech, they will have a tool to measure amps. If you want to buy one, Amprobe or Fluke are accurate and reliable. They will measure start/run amps as well as several other functions. The right tools are a safer way to work.
04-10-2021, 12:05 PM
My ac in 05 19 starts w/o the soft start. Start AC with fan off, then fan on.
04-10-2021, 01:38 PM
Trailer: Escape 21C
While Amprobe & Fluke make great meters (I have an Amprobe clamp on AC/DC meter), only some models can measure start up amperage. If that is what you want to measure, be sure to carefully read the specifications.
04-10-2021, 03:39 PM
Are you differentiating between "Easy Start", "soft start", and "hard start"?
04-10-2021, 07:25 PM
Wisconsin
Micro Air easy start
This tread was about installing Micro Air easy start, that I thought was a softy start.It has a clear case, and 4 wires. Went fine AFTER I found the correct instructions for my A/C. I do not know that a hard start would help over coming a small generator.
The EasyStart requires some moderately complicated wiring modifications that may be beyond the scope of the average RVr..
