Installing new 7-pin cable on Casita SD - Fiberglass RV
Old 09-05-2020, 09:55 AM   #1
Trailer: Casita SD 16
Maine
Hello FGRV,
I need some help locating where on a Casita SD I can install a new 7-pin cable. I see the wire clamp on the trailer but don't see any access box underneath. My Casita has a front mounted AC which would be just over that clamp. Before I tear the closet/AC area apart in search of it, is there a better/easier solution I'm not seeing? Thanks
macbethdt is offline   Reply With Quote
Old 09-05-2020, 10:08 AM   #2
Trailer: 2013 Escape 19
Get a weather proof J box and mount it on the tongue. Use the existing wiring to the J box. May sellers on ebay sell 7 pin plugs with a j box.
Old 09-05-2020, 10:39 AM   #3
I used a junction box on the tongue when I installed a coiled cord on our Casita SD. Had to use some sealer on the box because I found water could get in it.
Old 09-05-2020, 12:43 PM   #4
The gaskets on WP junction boxes usually do a better job of keeping water in then keeping water out . When we installed WP junction boxes we found that drilling some small drain holes in the bottom of the box worked the best
casita
$400 to wire a 7-pin cable in an Outback? nigeleccleston Electrical | Charging, Systems, Solar and Generators 19 10-03-2019 09:34 PM
Rerouting the 7 pin cable KarlB Electrical | Charging, Systems, Solar and Generators 3 08-27-2018 12:17 PM
Volvo European 7-pin to US 7-pin EllPea in CA Towing, Hitching, Axles and Running Gear 51 09-18-2015 05:05 AM
Changing from 6 pin to 7 pin on truck - how?? Shelley Towing, Hitching, Axles and Running Gear 4 07-28-2009 10:45 PM
Flat Pin vs Round Pin Connectors Legacy Posts Problem Solving | Owners Helping Owners 7 04-07-2003 11:34 AM
