Interior lights on 12V - Fiberglass RV
Old 08-13-2020, 04:44 PM   #1
Hello!
Very excited to share, that after 10 years of lurking fiberglass RV forums, classifieds, and new trailer company websites, I finally got my own!
I am super happy with my find, a lilí Bigfoot in great condition.
However, I thought I should be able to run the original 3 way Dometic fridge off of propane and still use the 12V battery for inside lights/electrical plug-ins but that doesnít seem to work. Is that not possible? Is there a switch I should be trying to find? The lights/plug ins work when connected to shore power.
2nd question; suggestions for where another power source could be hidden? Even with the battey disconnected the lights above each bed and the ďporchĒ light still work! I canít find the power source!
So many mysteries and I have no idea where to start!
I have very little knowledge so any recommendations need to be very explicit, lol! I have a feeling Iíll likely have to take it in for servicing ....
RVnewbie is offline   Reply With Quote
Old 08-13-2020, 05:25 PM   #2
John in Michigan's Avatar
Dana, after a ten year search congratulations on your new to you Lil Bigfoot! Great camper.
Trillium 4500 Journal
https://www.fiberglassrv.com/forums/f...nal-81345.html
John in Michigan is online now   Reply With Quote
Old 08-13-2020, 05:30 PM   #3
In response to your first question, yes 12 volt lights inside the trailer should work without shore power if there is a 12 volt battery. Electrical plug-ins should work if they are 12 volt or USB, AND if they wired back to 12 volt power panel (via the converter or 12 volt fuse panel).
Not sure how to answer your second question...
EDIT: Is the battery located on the tongue? Maybe look for a burnt out fuse. There could be an inline fuse under the front bench. Also check the fuses in the converter box.
Old 08-13-2020, 08:31 PM   #4
Trailer: 2003 21RB Bigfoot
Coos Bay, Oregon
Are you saying that the lights work off the 12V battery but when you turn the fridge on with propane they stop working? FYI - most fridges use a little 12V even when they are running on propane (to power the control board).
Yes, there can be more than one battery. I have one on the hitch and 3 inside a compartment in the trailer. Keep looking!
Congrats on the new trailer!
South Coast Stu is offline   Reply With Quote
Old 08-13-2020, 08:37 PM   #5
Thanks Stu and John,
Thus far the only battery I can find is under a bench, I have checked every cubby! There is none on the tongue. The 3 lights mentioned EVEN when I disconnect known battery, so there must be another source somewhere
I have checked all the fuses I can find, but I do not know what a converter box looks like?
Old 08-13-2020, 08:42 PM   #6
Coos Bay, Oregon
Question
What year is your Lil' BF?
I had a light in the canopy of of a pick-up that was powered by AA batteries (in the unit itself). Maybe?
PS: When most converters are on they will make a slight buzzing sound.
Old 08-13-2020, 09:10 PM   #7
The converter is the "electrical power box" that contains 110 volt AC circuit breakers to protect the 110 volt AC circuits (e.g., for outlets), 12 volt DC fuses, and an AC-to-DC power converter. The shore power cable powers it. It usually in one of the cabinets and has a front panel for accessing the circuit breakers and fuses.
The lights that work even with the battery disconnected may contain internal AA or AAA batteries.
Old 08-13-2020, 09:15 PM   #8
It is a 1987.
I am thinking the 3 lights, which are newer LED, may be small battery powered....but I disconnected the 12V battery and the water pump still runs, so there must be another power source somewhere.... I have checked everywhere!
Does the converter box look like a house fuse box?
Old 08-13-2020, 09:16 PM   #9
Thanks John, you posted just before I did. Thanks to you both!
Old 08-13-2020, 10:18 PM   #10
Coos Bay, Oregon
Question
How do you disconnect the battery? Are you plugged into shore power when you try this?
Here's an old post that has some good info. Franswa is very helpful. There is a pic of the load center that John described - AC breakers, converter/charger and DC fuses https://www.fiberglassrv.com/forums/...ing-75507.html It should have a brown cover and be located on the face of the drivers side bench. Twist the little black "thingy" 90 degrees and it should open.
Sure there isn't an extra battery on the tongue?
Old 08-13-2020, 10:20 PM   #11
I just disconnected the black (negative terminal), no shore power.
Old 08-14-2020, 08:38 AM   #12
Coos Bay, Oregon
I'm still not understanding if the lights work until you turn the fridge on propane (and it works fine?). What model fridge?
Did you find the load center yet? It sounds like there has got to be another battery somewhere. If not, you have discovered how to make electricity out of thin air Don't sell that trailer!
Here's a post from trouble I had with my fridge and 12V power. I finally found a fuse that was tucked away. https://www.fiberglassrv.com/forums/...rce-83415.html
It really sucks sometimes that there are no factory wiring diagrams that come with these trailers
Old 08-14-2020, 04:21 PM   #13
Hi Stu
No the main inside trailer lights only seem to work on shore power. When I have the fridge on propane, it was my assumption that the lights would run off the 12V battery- but no such luck. Iím not sure of the model #- will have to get back to you, itís the original dometic though.
A separate mystery is the 3 lights and water pump that seems to work on by there selves lol.
I found the converter box, fuses are ok.
I have a service guy coming, Iíll let him figure it out!
Thanks everyone!
Old 08-14-2020, 09:54 PM   #14
AC0GV's Avatar
Wisconsin
Tow vehicle??
Originally Posted by RVnewbie View Post
Hello!
Are you plugged into the tow vehicle at the time? If you have a seven pin that too can supply power.
That whole thing sounds like someone did a re-wiring job. Please let us know what he finds.
Old 08-18-2020, 07:58 PM   #15
Deadhead517's Avatar
Name: Alan & Barb
Trailer: Bigfoot 25RQ
First of all, congratulations on your new trailer! As a Bigfoot fan myself, I am quite jealous that you found a little Bigfoot. As to the electrical question, I didn’t see anybody asking what would appear to be an obvious question and I’m sure you already figured this out but with these lights that are working when the battery is disconnected is the tow vehicle connected? Good luck on resolving it.
Deadhead517 is offline   Reply With Quote
Old 08-18-2020, 10:40 PM   #16
AC0GV's Avatar
Wisconsin
I asked that and...
Originally Posted by Deadhead517 View Post
First of all, congratulations on your new trailer! As a Bigfoot fan myself, I am quite jealous that you found a little Bigfoot. As to the electrical question, I didnít see anybody asking what would appear to be an obvious question and Iím sure you already figured this out but with these lights that are working when the battery is disconnected is the tow vehicle connected? Good luck on resolving it.
...the OP never came back. So I'm guessing that was the case.
Old 08-19-2020, 09:28 AM   #17
ZachO's Avatar
Trailer: 91 Bigfoot 17
Montana
Fridge operation has nothing to do with other 12v operation. Because you've been mentioning the fridge on propane in relation to 12v electronics working, I'm assuming there's a misunderstanding about how the system should work that we should clear up. Can you explain the fridge/propane/12v system connection you're talking about?
Good work on the Bigfoot!
We'll get all this stuff figured out
light, lights
Run 12V TV/monitor off of 12V outlet or via inverter? Rod Scher Problem Solving | Owners Helping Owners 22 11-19-2016 02:11 PM
Brake Lights, Turn signal lights, marker lights, oh my! glamourpets Problem Solving | Owners Helping Owners 19 01-03-2013 10:10 AM
Hunter I Interior 12V Lights BuffaloTrails Problem Solving | Owners Helping Owners 4 11-08-2010 05:09 PM
Reading lights-looking for 12V (non-halogen)-maybe LED'S? JenW Problem Solving | Owners Helping Owners 30 09-21-2007 10:38 AM
Adding 12v Sockets & Lights peterh Problem Solving | Owners Helping Owners 17 12-13-2006 04:24 PM
