I found these bad boys on Amazon for $8 a piece.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Installing them were pretty easy. I unscrewed the old taillight assemblies, Cut the wires from the assemblies, capped off the red wire for the reverse
lights, crimped the wires with butt connectors and attached the
tail lights. Obviously the hole patterns are slightly different. Thankfully the bottom screw holes in the new
lights nearly matched the existing screw holes in the trailer. The top ones, however, did not. I filled the top holes in the trailer with marine tex, drilled new holes for the top holes of the new tailights, and riveted them to the trailer. Anyways, the results were pretty good.
This is of the
tail lights and not the brake
lights. The taillights are bright as it is. The brake lights are truly noticeable. All in all it took me about an hour to remove the old ones and install the new ones. Technically the lights are flipped (the
license plate
light is actually suppose to be the right one, apparently) but they work as intended and I like the way they look...
