Lil bigfoot breaker panel - Fiberglass RV
Old 07-17-2022, 09:59 PM   #1
Trailer: Lil bigfoot
I’ve been giving my lil bigfoot a going over since purchasing about a month ago. I think I’ve got the dc side worked out and the ac side is functioning but in checking it out I was a bit confused with how the panel is wired. It looks like they have the feed coming through one breaker and then jumpered to the other.
Is this typical? I figured it would make more sense to feed both breakers from the cord coming in and have two separate circuits.
Nick G is offline   Reply With Quote
Old 07-18-2022, 08:56 PM   #2
CharlesinGA's Avatar
Well, you certainly guessed correctly. Actually the upper breaker is the MAIN breaker, and the one it jumpers (the lower one) is the one for a "branch circuit". That is a old Square D type QO 240v air conditioner disconnect, which they have adapter to the purpose.
Charles
'03 Ram 2500 CTD, 5.9HO PacBrake six speed std cab long bed Leer top and 2008 Bigfoot 25B21RB.. Previously, 2008 Thor Freedom Spirit 180, SOLD! 2007 Winnebago View 23H Motorhome, SOLD!
CharlesinGA is offline   Reply With Quote
Old 07-20-2022, 08:14 AM   #3
Joe MacDonald's Avatar
Trailer: 1981 Trillium 5500
you have only a 120v feed supply, and any supply needs to be switchable inside a building/trailer, that's why one is considered main, one is branch.
however, if you really wanted to separate you two 120v circuits, you can get a tandem breaker that gives 2 feeds with two handles and fits in the space of a single, but they are expensive.
Joe
Old 07-20-2022, 09:15 PM   #4
You can fit this in the place of the lower breaker in the pic and have two circuits, controlled by two breakers.
https://www.amazon.com/Square-Schnei...ef_=ast_sto_dp
$28
Charles
Old 07-21-2022, 10:44 AM   #5
EllPea in CA's Avatar
Trailer: 1989 Lil Bigfoot
CA
Welcome to the world of the Lil Bigfoot!
Best,
EllPea in CA
EllPea in CA is offline   Reply With Quote
Old 07-22-2022, 07:58 AM   #6
Thanks everyone.
Good to know trailers are wired more or less as a house. It still hurts my brain a little to have a main breaker controlling only one other breaker. A split breaker is a good idea to make give the main breaker a purpose in life but I don’t know if the feed if big enough to handle more than 15 amps anyway. I’ll probably leave it as is for now and have a sparky upgrade the ac side of things down the road.
Old 07-25-2022, 05:30 AM   #7
My 5500 has only a 15 amp feed, I use the breakers more as switches so I can isolate different areas when using the trailer, or working on it.
Joe
bigfoot
I Installed a Solar Panel for my Lil Snoozy HomeCamp Electrical | Charging, Systems, Solar and Generators 55 03-08-2021 09:21 AM
Location breaker panel on 2008 Scamp 13' ? Mike L. Problem Solving | Owners Helping Owners 12 09-20-2013 01:24 PM
Solar Panel Set up Question - Grounding the panel? Anne H Electrical | Charging, Systems, Solar and Generators 2 09-07-2012 04:48 PM
How to hook up Inverter to Breaker panel zoshia Electrical | Charging, Systems, Solar and Generators 10 07-30-2012 07:06 PM
Where does the circuit breaker go? Legacy Posts Problem Solving | Owners Helping Owners 7 07-17-2003 08:47 PM
