Lithium battery - Fiberglass RV
Old 05-09-2020, 09:36 AM   #1
West Virginia
Question Lithium battery
Should I keep my 2019 Casita with a lithium battery plugged up while it is stored?
thanks,
Ralph
RLJR is offline   Reply With Quote
Old 05-09-2020, 10:00 AM   #2
Raspy's Avatar
Trailer: Black Series HQ19
Smith Valley, Nevada
I don't think you need a float charge on lithiums, what does the manufacturer of your battery say about this? But you will need to keep up with any parasitic loads, like the CO/propane detector, tank monitors, etc. Things you cannot shut off unless you disconnect the battery, when stored.
Old 05-09-2020, 11:48 AM   #3
Jon Vermilye's Avatar
Trailer: 2017 Escape 21
Oswego, NY
thanks,
Ralph
The recommendation from Battleborn is to let the battery drop to 80%, then store without a load or float. Mine dropped around .1V during a month of storage.
Old 05-10-2020, 05:02 AM   #4
West Virginia
Battery
I bought the camper second hand. The manual doesn't cover much. In winter I go out and fool around with it some and having it hooked up is handy, however it is easy to hook up. I am installing a battery shutoff switch and I will be unhooking the cord and the battery this coming winter.
If you guys disagree with this procedure let me know.
Thanks for your help, Ralph
Old 05-10-2020, 08:39 AM   #5
Oswego, NY
While I doubt it will be a problem in West Virginia, if the outside temperature goes below -20°F, Battleborn recommends bringing the battery inside.
battery
Need advice on replacing lead battery to AGM or Lithium? Losthwy Electrical | Charging, Systems, Solar and Generators 30 05-21-2020 05:03 AM
Lithium battery in Lil Snoozy Air Doug Electrical | Charging, Systems, Solar and Generators 64 12-23-2019 08:30 PM
2.4 Kwh Lithium Battery pack Sparky0 Modifications, Alterations and Updates 39 08-07-2019 11:23 AM
Ordered a 100 Ah Lithium Battery Huck Electrical | Charging, Systems, Solar and Generators 41 07-14-2018 07:15 PM
RV Lithium Battery honda03842 General Chat 20 07-16-2015 03:47 PM
