Lithium Battery Charging from TV - Fiberglass RV
Old 12-22-2024, 06:44 PM   #1
Does anyone know which wires in the Casita closet go from the 7 pin Tow vehicle to the battery for charging?
I have a small Lithium Ion battery that I use to run my rather minimal electric needs and I want to charge it from the tow vehicle using an Orion-Tr 12 to bump the voltage to 14.4 Volts. I don't know which wires in the closet I need to intercept.
I know this topic has been discussed a bit but I cant find where anyone has addressed this.
Thanks.
swhird is offline   Reply With Quote
Old 12-28-2024, 11:19 AM   #2
LarryB.'s Avatar
Trailer: Casita17'Spirit Deluxe (aka: Tweaker's Casita)
Southwest Ohio
According to the Wiring diagram DI-1 in the "Casita Travel Trailer A-Z OWNER'S GUIDE", the black wire goes to the +12v terminal on the battery and the white wire goes to the negative terminal on the battery.
LarryB. is offline   Reply With Quote
Old 12-28-2024, 11:40 AM   #3
Trailer: Holidaire
Thanks.
Be careful, there things you need to do: https://battlebornbatteries.com/char...ading-anchor-1
matthfam is offline   Reply With Quote
Old 12-28-2024, 02:01 PM   #4
Trailer: 1977 Scamp 13
You will need a DC-DC charger which run $100-$250 if you want to charge from your TV.
I have a 50 amp hour lithium battery running some lights, phone charger and occasionally hook up an inverter to charge a laptop. In cold weather I use a diesel heater which will run a couple 10 hour nights on a full charge.
I use a 100 watt solar panel with a charge controller that will charge my battery in a couple hours of sun to full after a night running the heater, longer if partly cloudy, of course. It is a simpler setup that cost me $100 total.
John LF is offline   Reply With Quote
Old 12-29-2024, 09:46 PM   #5
This is very similar to what I'm doing. I have a 20AH Lithium battery that will last me several days even in light winter running the lights, a monitor, fridge electronics (on gas), water pump, and a little bit of heat. I'm able to keep it charged indefinitely with a 100 W solar.
Connecting the TV discharges my Lithium battery (unless I disconnect it) so I want to add the DC-DC.
Old 12-29-2024, 09:47 PM   #6
Mathhfam - Thanks. I will be careful.
Old 12-29-2024, 09:49 PM   #7
Thank You. The owners guide that I found showed wiring but the colors were not readable.
Old 12-30-2024, 09:38 AM   #8
Trailer: Casita Independence
Wisconsin
Here you go
Around a campfire everyone is a raconteur - Campdude
Escape 15A is offline   Reply With Quote
battery
Lithium battery in Lil Snoozy Air Doug Electrical | Charging, Systems, Solar and Generators 88 01-18-2022 05:09 PM
Ordered a 100 Ah Lithium Battery Huck Electrical | Charging, Systems, Solar and Generators 84 06-21-2021 08:55 PM
Need advice on replacing lead battery to AGM or Lithium? Losthwy Electrical | Charging, Systems, Solar and Generators 37 09-20-2020 02:46 PM
RV Lithium Battery honda03842 General Chat 20 07-16-2015 03:47 PM
Charging Battery and running battery lights when plugged in Nor_Cal_Todd Problem Solving | Owners Helping Owners 2 08-25-2010 01:44 PM
