Originally Posted by Campingbliss
I have a Renogy 100w solar suitcase (with attached charge controller) that I charged my lead acid battery with. I just swapped the battery out for a Battleborn lithium ion 100ah battery and am wondering if the solar suitcase is equally compatible since the new battery can charge to 14.4v instead of the 13.2v on the lead acid battery. Do I have to do anything special to the controller to get the add'l voltage? I'm kind of a newbie with solar and charge controller stuff.
My Voyager 20amp and 10amp Wander both are LifePo4 compatible, just set the battery you are using. Not sure about the suitcase mounted controllers, but I believe it is compatible.
Line 6 under “Key Features”
https://www.renogy.com/100-watt-12-v...BoC3R8QAvD_BwE
From Renogy website
“DESCRIPTION
If you're looking for a convenient and portable power solution, the Renogy 100W Monocrystalline Foldable Solar Suitcase is the ideal choice.
The Renogy 100 Watt 12 Volt Monocrystalline Portable Solar Suitcase is an entire
solar power system incorporated into a single, compact package.
Weighing in at about 26.60 lbs., this lightweight suitcase includes two 50-Watt Monocrystalline Solar Panels, one 20 Amp waterproof Voyager Charge Controller with an LCD Screen for power regulation, one 10ft tray cable with alligator clips for easy connection to the battery, and protective casing for safe portability. The Renogy 100 Watt Solar Suitcase will make charging on the go as easy as 1-2-3!
If you have any questions regarding this product, please call us at 1 (909) 287-7111 or email
support@renogy.com.
KEY FEATURES
Reliable
Adjustable, corrosion-resistant aluminum stand
Heavy duty handle and latches for longevity
Protective casing
Smart
Compatible with gel, sealed, lithium, and flooded batteries
Charge controller with LCD display for displaying operating information and data
Safe
20A built-in 5-stage solar charge controller provides overcharge protection, reducing fire risk
Negative-ground charge controller for compatibility with an RV, boat, trailer, etc.
The low-voltage system avoids
electrical shock hazards
Portable Power
Easy to pack and setup
solar power kit. Foldable, and sturdy
solar panel for outdoor activities, hiking, camping, events, road trips, and easy to carry off grid power.
Easy to Use
Read to power your car or RV battery bank anytime. Easy alligator clip and battery connection using the provided adaptor cables.”
So it appears using your suitcase just as you would with a lead acid battery is fine, as long as you change the “profile” in the battery selection of the controller to Li, and it should charge appropriately.
