As stated previously I have the WFCO AD (auto detect) charger/power center. I purchased a cheap (amazing the price range of lithium batteries) 100 AH type 31
battery (LiTime).
Removed my factory type 31 AGM - The LI
battery fit the same except for a slight difference in length (longer), and height (shorter) by a few fractions of an inch. I drilled new holes in bracket to hold it and placed a wood block on top so it can't bounce up / down, then reattached factory wiring.
Battery came with a charge so I ran the
refrigerator on DC mode (power hungry!) over night; in the morning Battery was 'dead' - I assume the BMS shut it down.
Then I plugged into house current to charge the new LI Battery - showed 14.45 Volt while charging on that cheap little battery gauge that
Casita gave me with the trailer. According to WFCO the converter does not 'auto detect' until the battery is fully discharged and then fully charged; ‘a complete charging cycle’ and it detects the sharp 'drop off' of the LI battery at the end of charging cycle. Now (3hr charge?) shows 13.4V not plugged into house current. My chart says that’s a 99% charge, I'll take it!
Notes: WFCO has a green, red and blue LED in fan compartment (hard to see). Green is Lead Acid charging profile, Blue is Lithium profile, Red in conjunction with one or the other means a depleted battery that is charging.
Sorry for the long winded reply - thought someone may benefit from my research / experiment.
Bob
