Looking for easy Renogy suitcase connection - Fiberglass RV
Journey with Confidence RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 05-12-2022, 03:25 PM   #1
Trailer: Scamp 13’
Wisconsin
I bought a Renogy 100W suitcase, which comes with a cable with alligator clips to connect to the battery. Anyone come up with a quicker, easier way to make the connection, preferably without having to open the battery box?
I must admit I have no electrical experience, and am somewhat afraid of electrical work, so I would prefer to buy equipment that is plug-and-play rather than having to do any wiring myself.
sunnyone is offline   Reply With Quote
Old 05-12-2022, 03:49 PM   #2
Name: You can't call me Al
Trailer: 1977 Scamp 13'
Massachusetts
I'm not 100% sure what renogy model you have, but from what I see in the web, maybe you need a "MC4-to-SAE" and an "SAE-to-Ring"
https://www.amazon.com/Vemote-Connec.../dp/B08ZHX51D4
https://www.amazon.com/SUNER-POWER-W.../dp/B09CDBK3NM
You could then leave everything connected and disconnect at the "SAE" connector.
AlanKilian is offline   Reply With Quote
Old 05-12-2022, 04:51 PM   #3
Trailer: Scamp 13’
Wisconsin
It’s an Eclipse 100W suitcase, and it does have MC4 connectors, so looks like those cables would work.
Old 05-12-2022, 05:01 PM   #4
ShelbyM's Avatar
Trailer: Casita SD
That's a good plan. I made similar connectors for my suitcase but would have just bought some if I'd known they were available. I fish the cable through a vent in the bottom of the cave, don't have to leave the door open when connected.
Old 05-12-2022, 06:56 PM   #5
Trailer: Casita SD
You could connect your suitcase to the charging + and - pins on a 7-pin hitch receptacle, and then use it with your Scamp's 7-pin plug.
I did something similar with a Renogy Wanderer panel controller - Mounted it inside a cheap Harbor Freight "waterproof" carrying case:
JoelInTexas is offline   Reply With Quote
Old 05-12-2022, 07:01 PM   #6
Trailer: 2009 Escape 17B
Being water proof, what about heat build up? How do you cope with that?
Old 05-13-2022, 07:11 PM   #7
Trailer: Casita SD
^There is no significant voltage drop across this particular solar panel charge controller, and maximum rated charge current is 10 amps - so there is no significant heat generated.
Old Yesterday, 11:08 AM   #8
Trailer: Casita 17 ft SD
Power
Try the Andreson Power Pole, do an online search or go to Ham Radio Outlet.
ehoepner is offline   Reply With Quote
Old Yesterday, 01:00 PM   #9
Trailer: 2016 -13' Scamp
Massachusetts
Following.
herons is online now   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Tony Nowak
Use Trolling Motor Battery Box for Easy Solar Panel Connection GpaNed Electrical | Charging, Systems, Solar and Generators 11 12-07-2021 03:37 PM
Opinions on Renogy ultra-light solar suitcase? Spongelander Electrical | Charging, Systems, Solar and Generators 19 01-12-2019 02:29 AM
Renogy 60w Suitcase Solar ColoradoSwany Classified Archives 0 01-04-2019 02:03 PM
Suitcase, Solar Geek ? Eddie Longest Electrical | Charging, Systems, Solar and Generators 6 04-30-2017 07:13 PM
Suitcase satelite dish ~ Sold Gina D. Classified Archives 1 10-22-2006 11:55 AM
