Nova Kool refrigerator - Fiberglass RV
Old 11-24-2020, 11:15 AM   #1
Hollywood
Has anyone installed a Nova kool fridge in their Scamp?
I have a 1987 19' scamp and want to go to a 12 volt preferably two door refrigerator.
Tcjmiami is offline   Reply With Quote
Old 11-24-2020, 04:30 PM   #2
sokhapkin's Avatar
SW Florida
Which fridge model? They make a wide range of fridges based on different technologies. From absorption fridges to compressor-based.
Sergey
Old 11-25-2020, 04:05 PM   #3
Idaho
I installed a Nova Kool fridge. The model 2600 fit in the old space well. I already had a 100watt solar, so just connected it up to that. Actually that part I had done by an electrician as I consider electricity a form of magic. I just got the DC model. It has worked superbly for me!
PilotPica is offline   Reply With Quote
Old 11-25-2020, 08:28 PM   #4
Hollywood
I am still deciding what model.
Thank you for the reply
Old 11-25-2020, 08:30 PM   #5
Hollywood
Was this in a 19 foot scamp?
Old 11-25-2020, 08:46 PM   #6
How are you set up in terms of batteries and recharging? You said a 2-door unit, so that sounds like a larger one.
Old 11-25-2020, 09:19 PM   #7
Hollywood
I am specing out the system before I start.
I see limited boon docking and will run a generator if necessary.
Old 11-26-2020, 09:06 AM   #8
TN
You mention a specific brand of 12 volt refrigerators. I would suggest you extend your search to off grid or solar refrigerators. The primary difference that I have seen is the Marine/RV specific units have a latch mechanism on the doors. Not worth double the cost.
Eric Frye is offline   Reply With Quote
Old 11-26-2020, 10:19 AM   #9
Idaho
No, sorry it's in a 13'
Old 11-26-2020, 06:16 PM   #10
Hollywood
Good idea.
Can you recommend a source?
Old 11-26-2020, 06:45 PM   #11
Idaho
Sure. I ordered through Backwoods Solar which is in Sandpoint Idaho. Their phone number (208)263-4290. They are very helpful! and I get the impression they can be be helpful with the solar connection part too.
Old 11-27-2020, 08:10 PM   #12
TN
I found mine at Ben's discount supply. https://bensdiscountsupply.com/
If you do a web search there are a couple of others sites like Ben's. Also check some of the Marine supply sources as well.
Old 11-28-2020, 07:17 AM   #13
Hollywood
Rec Pro Refrigerator
Has anyone used a Rec Pro refrigerator?
If so what compressor does it use and does it seem to be efficient?
Old 11-30-2020, 06:18 AM   #14
TN
I looked at the RecPro site and the larger 12V refrigerators are clearly marked cyclopentane. That is a common refrigerant used today. It is odd that they don't give you much information on the 3.3 cu/ft unit where as the larger units it list startup amperage and running average amperage. I would call RecPro and ask them about the unit just to verify it is a 12V compressor unit and get the specifics on power usage.
I would suspect it is cyclopentane compressor unit with a start up amperage of around 7 amps and a running usage of around 1 amp. The 15 amps mentioned on there site is probably the recommended circuit size.
I have purchased from RecPro in the past and been happy with them if it is any help.
Old 12-04-2020, 06:35 AM   #15
Joe MacDonald's Avatar
Trailer: 1981 Trillium 5500
is there a reason you don't want propane? I just installed a Norcold n3150 double door in my trillium and love it
Joe
refrigerator
Upgraded to a Nova Kool R3000 ajdemo76 Modifications, Alterations and Updates 0 05-30-2015 07:05 PM
Keeping it Kool. Boler77 Problem Solving | Owners Helping Owners 0 08-14-2011 10:31 PM
Very Kool looking 16' Boler? Jake Classified Archives 5 07-27-2011 07:48 PM
2010 Custom Fiberglass teardrop"Real Kool" Dave Baston Referrals: Molded Fiberglass Trailers 1 06-07-2010 05:14 PM
Nova Kool refrigerator hamidf Problem Solving | Owners Helping Owners 6 04-30-2006 04:07 PM
