I’m restoring an ‘83 13’ and have removed all existing
electrical and replaced with new wiring, fixtures, and outlets. I installed a PD4045KV power center, and have all the AC side wired, the converter hot connected to a breaker, and the ground bus grounded to the chassis. No problem there at all.
However, I am stuck on the DC side. I have all of the positives in their respective circuits, and the negatives connected to a separate bus bar I installed on the floor behind the unit. However, I have no idea where to connect this bus bar. Do I connect the battery’s negative cable to the bus bar and then the bus bar to the
battery negative terminal on the PD4045? I need someone to explain what to do in the simplest terms possible lol. Pics of the front of the unit and the rear of the unit+bus bar included, and I have no idea why the site rotated my pictures, but I promise I did not install the unit upside down!
