Originally Posted by Dsironi
Steve,
I expected as you did. Note the center photo of my first posting. There is a slight red showing on the right side of the indicator. I had not noticed that. Is that the indicator you refer to? If so, I may not need a new one. I just need to be more observant. Thanks for the clarification on how this regulator works. I too expected to see the knob turn, but I couldn't understand what force would move it.
David, am I Scamping?
The original regulator that came with my
Escape had an indicator like the one you are describing. It barely turned red when the tanks switched. The result - running out of
propane at the Grand Canyon in 25F temperatures with the closest refill 30 miles away. I switched to one that has a more positive indicator. I switched to a
Marsh Excel regulator which only has a small window in the front, but makes a full color change when the tanks switch. I use a dental mirror to check since I have a hard cover on the tanks.
