Question re negative wires - Fiberglass RV
Old 08-16-2022, 05:36 PM   #1
Name: Kate & George
Trailer: Boler 1300
AB
Wiring - what to do with negative wires:
So, I added this larger fuse panel to make room for 2 new 12v accessories. The existing negative wires all go to marrette in a switch box that is labeled “UP for 110”. Should I bring the new negative wires here (already a bit crowded), or patch down to the fuse panel, and bring the negative down to there? Seems like it should be the latter?
CAA76D4F-25DE-4E48-AD2E-F7FD60E83621.jpg   C0902AFE-1FD7-4228-9A84-06E5518AD3DF.jpg
Kate W is offline   Reply With Quote
Old 08-16-2022, 06:41 PM   #2
What is a marrette?
Old 08-16-2022, 08:04 PM   #3
AC0GV's Avatar
Wisconsin
marrette ??
Originally Posted by Darwin Maring View Post
What is a marrette?
Twist-on connectors are also known as wire nuts, wire connectors, cone connectors, or thimble connectors. One trade name for such connectors, Marrette, is derived from the name of their inventor and, in Canada, this type of connector is often referred to as a marrette regardless of the actual brand of the product.
Old 08-17-2022, 08:13 AM   #4
Joe MacDonald's Avatar
Trailer: 1981 Trillium 5500
first, that switch setup looks kinda sketchy, even if it is only 12v, I see the potential for shorts, and that switch is not DC rated, second, the bottom of your fuse panel has a negative bus bar already for your connections, the 12 screws, and the stud where it says "-".
get a DC rated switch and a mounting bracket, like https://www.amazon.com/dp/B07T288VN8...8c8d8ee02&th=1
Joe
Old 08-27-2022, 12:25 PM   #5
Name: Kate & George
Trailer: Boler 1300
AB
Thanks for making that clear explanation for me, AC0GV.
Old 08-27-2022, 12:34 PM   #6
Name: Kate & George
Trailer: Boler 1300
AB
Joe
This discussion is very enlightening. When we bought the Boler it actually had no fuses, but we had some added when we added a furnace. We’ve had 3 rv shops look at it and not one has said “your wiring is unsafe”. I bought the fuse box with negative wire slots because clearly that will be better than trying to gather all the negative wires in one place. I didn’t even think about the switch being an improper switch altogether. I want to make the wiring correct, but it is sure hard to find good basic learning resources for that.
Wiring - what to do with negative wires Kate W Problem Solving | Owners Helping Owners 1 08-17-2022 01:38 AM
Question on Wiring 12V Fuse Block with Negative Bus kellyben Electrical | Charging, Systems, Solar and Generators 8 01-24-2018 05:40 PM
1972 Hunter Compact Negative Camber Issue luckycharm Towing, Hitching, Axles and Running Gear 5 07-21-2014 07:25 PM
Lighting wires and sink pump wires in Burro Kemoldenhauer Problem Solving | Owners Helping Owners 3 08-14-2013 10:06 AM
stupid mistake connecting positive to negative on battery lloyd cicetti Electrical | Charging, Systems, Solar and Generators 2 07-04-2013 05:10 PM
Copyright ©2000 - 2023, vBulletin Solutions Inc.
