Running light covers - Fiberglass RV
Old 09-09-2024, 02:53 PM   #1
Trailer: Scamp 13 ft
Hello,
I'm a proud owner of a 1999 13ft Scamp.
I lost a running light cover and another is broken.
Should I replace the covers or is now the time to replace with LED lights? Is it more complicated then what it's worth.
Thanks for your thoughts
Dianne
Dianne Graf is offline   Reply With Quote
Old 09-09-2024, 07:36 PM   #2
We had a running light cover break on our 2011 Casita. The guys at the RV shop said, everyone uses the same style, it's called "Winnebago". They didn't sell the lens itself, you had to buy the entire unit. Which wasn't expensive, really.
In our case, we used 12v bulbs. If I were to do it again, I'd use LEDs, but I don't know if that requires rewiring it?
If so, I'm the wrong person to ask, I'm a field biologist, not an electrician. And quite honestly, the amount of juice it takes to run the 12v light bulb for the relatively short amount of time you have the running lights on, I doubt there's much in difference in the amount of electricity used in either one.
Meadowlark is offline   Reply With Quote
Old 09-10-2024, 12:39 PM   #3
Trailer: 1971 Hunter compact Jr, 1979 Terry 19', 2003 Scamp 16'
If you can find the covers just replace the bulb with led bulbs. Cheap an easy. Some require correct polarity others don't. I purchased mine from Amazon 8 years ago.
Terry in Fowler is offline   Reply With Quote
Old 09-15-2024, 12:48 AM   #4
CharlesinGA's Avatar
If they use bulbs it is probably a 194/168 style. I bought a bunch of 194 cob style from Superbright LEDs (probably the only time I didn't buy from M4 Products) the bulbs work well but are polarity sensitive and if they don't work, pull them out and reinsert them the opposite way.
I bought ten, planned on using them for the tag light on my older RAM but the can bus system didn't like them and would not power them up.
I did install one on the new tag light fixture I installed on my trailer (and tested it for polarity before installing), and used one in the dome light on my old Ranger (mucho brighter!). The LEDs will fail eventually so buying dedicated fixtures are not a good idea. I want replaceable lamps. I used these on the marker lights on a Thor trailer I had. Even with me blanking out the tag, I think you still get the idea how bright it is. I did add aluminum tape inside to act as a reflector.
Charles
Tag Light 00 new 194 168 LED COB light.jpg   Tag Light 00 Finished installation.jpg
'03 Ram 2500 CTD, 5.9HO PacBrake six speed std cab long bed Leer top and 2008 Bigfoot 25B21RB.. Previously, 2008 Thor Freedom Spirit 180, SOLD! 2007 Winnebago View 23H Motorhome, SOLD!
CharlesinGA is offline   Reply With Quote
Old 09-16-2024, 10:01 AM   #5
Trailer: 1977 Scamp 13
I like camping in out of the way places that often have rough roads. My original running lights were requiring a few whacks frequently to keep them working and one of the lenses was cracked. Several years ago I replaced them with something similar to these. https://tinyurl.com/mryxpa84. They have a protective metal frame and rugged glass lenses. They have never failed to work and stay lit on the roughest of roads. I expect them to last decades. About double the price of the cheap plastic ones, but still less than $10/each
Installation is very simple. You just have to attach the wires to the existing circuit being sure to do so with the correct polarity. (if you get it wrong it will not damage anything. Just reverse the wires)You might have to drill a couple holes to attach them to the shell.
John LF is offline   Reply With Quote
light
Covers and Carport Covers and Solar Breakdown mosquito13 General Chat 1 07-22-2023 07:13 PM
another running light problem rabbit Problem Solving | Owners Helping Owners 12 02-20-2011 12:08 PM
Play Pac Running Light Bonnie Classified Archives 1 09-30-2007 06:27 AM
Scamp brake and running light trouble Dennis J. Kane Towing, Hitching, Axles and Running Gear 24 07-20-2007 07:55 AM
Triple E Surfside TM-14 left front running light cover Cam A Classified Archives 5 05-03-2006 06:27 AM
