Scamp Running Wire - Elephant Skin - Fiberglass RV
Old 05-25-2021, 10:31 PM   #1
Utah
Hey All!
Has anyone ran wire behind the older "elephant skin" walls Scamp used to put in their trailer?
I need to run a few feet of wire from one cabinet to the next and it will be exposed unless able to hide it behind the elephant skin somehow. I was thinking about cutting a strip and pealing that strip off, leaving a channel for the wire. From there was going to put caulk over the wires to hide it. I caulked where the old tape used to be and painted over and it turned out very nice. Was thinking the same thing but with wire could work. Can wires be covered with caulk or will it cause them to get hot?
Thanks!
Spencer
TheSpencerJM is offline   Reply With Quote
Old 05-26-2021, 12:10 AM   #2
Steve Outlaw's Avatar
Trailer: Oliver Legacy Elite II
Mississippi
The wires will not get hot just because you covered them with caulk.
Steve and Tali - Dogs: Reacher and Lucy and our beloved Storm and Maggie (waiting at the Rainbow Bridge)
2017 Silverado High Country 2500HD Diesel 4x4
Steve Outlaw is offline   Reply With Quote
Old 05-26-2021, 04:31 AM   #3
Phil Underwood's Avatar
Trailer: Tri Fab
Odem,Texas
you will be fine
Phil & Denise Underwood
1973 13ft Lovebug
2001 Dynamax
Phil Underwood is offline   Reply With Quote
Old 05-26-2021, 07:28 AM   #4
Name: You can't call me Al
Massachusetts
I would try pushing something behind the elephant skin from one cabinet to the other to make a passage for the wires.
Then pull the wires through using whatever you used to make the passage.
Something like a straightened wire coat hanger or maybe a skewer from the kitchen?
I have some very heavy copper wire I use to push behind things like this.
AlanKilian is offline   Reply With Quote
Old 05-26-2021, 10:20 AM   #5
Massachusetts
"Elephant skin" was used before "Rat fur."
It's what my 1977 13' has inside.
I think it's called Ensolite?
Old 05-26-2021, 10:42 AM   #6
Trailer: Trail Cruiser
I don't know if this will work in your situation but I bought a "fish tape" from Harbor Freight to feed wire through walls etc.
Old 05-26-2021, 10:44 AM   #7
Originally Posted by TheSpencerJM View Post
.. Can wires be covered with caulk or will it cause them to get hot?
In fact the current ratings for wiring does change depending on the insulation, the conduit its run in and how many wires are run together, based on heat generated. The max safe current of the wire(s) will be less when covered with caulk or anything else, compared to being in free space.
That being said, the difference is almost surely trivial unless you are close to the limit. I would not be concerned about it.
I heard people use piano wire to fish wires under the wall covering. Or your can purchase a fish tape: https://www.amazon.com/Best-Sellers-.../hi/6396129011
Old 05-26-2021, 11:25 AM   #8
David Tilston's Avatar
To keep the fish tape, (or coat hanger) from coming through the Ensolite, bend the tip slightly towards the fibreglass. This will make it want to scrape the fibreglass vs. poking through the Ensolite. It may also cause it to jam on the rough surface of the fibreglass. Just give it a slight twist, back and forth to free it up.
Old 06-02-2021, 11:11 AM   #9
Trailer: 74, 13' Boler
We ran wires for the maxxfan from the upper cabinet, 6" to the fan and found ensolite does not peel well and can rip easily. Once it's done you can see the bump where the wire is. A short run like that is ok but I wouldn't try to run long distances unless I absolutely had to.
To run the power for the cabinet lights we stuck "wiremold" to the wall next to the window. It's cut to length and has a peel and stick back. I used wiremold inside the upper cabinet to protect the wire for the pot lights.
Josh Robinson is offline   Reply With Quote
Old 06-02-2021, 01:35 PM   #10
I did something simmilar to what Josh describes.
Old 06-02-2021, 05:18 PM   #11
Trailer: 2014 Escape 21, Lil Joe
When running wires in ensolite seams I usually hot glue the wires to the shell first. I makes them easier to calk over when the wires are glued in place first.
Eddie
Old 06-02-2021, 07:40 PM   #12
IllAnnoy
Assuming 12V...
I have typically used a piece of #9 rigid (non electrical) wire to for a "needle", Attach the wiring as "thread", then simply slide the needle under the elephant hide and pull the wire through... works great!
Another way is to buy a white extension cord to use for surface mount.
You could even use a razor knife to cut a slit in the e-hide, insert the wire the glue it back down.
How to remove elephant skin? Sybilcat Problem Solving | Owners Helping Owners 7 12-18-2015 09:13 PM
1982 scamp elephant skin wall Jiggs Care and Feeding of Molded Fiberglass Trailers 2 10-31-2015 09:06 AM
Elephant skin alternatives Camper Creative Modifications, Alterations and Updates 7 10-19-2015 06:28 AM
Elephant Skin -Scamp SimplyLesa Problem Solving | Owners Helping Owners 3 08-11-2014 03:55 PM
Carpeting over "elephant skin" steve in texas Problem Solving | Owners Helping Owners 12 07-31-2011 04:50 PM
