Side lights not working - Fiberglass RV
Old 05-29-2022, 07:16 PM   #1
Hi guys,
I just purchased and installed new side lights for my Boler.
The ground is either of the bolts which actually fasten the light in place on the trailer.
When I try to test these lights using a small 12v battery, none of them work.
My current tester is showing that current is passing through the light, but it is not actually lighting for some reason.
Fairly sure it is a grounding issue, but can't be sure.
Can anyone shed any light on this?
Thanks,
Niall
Niall is offline   Reply With Quote
Old 05-29-2022, 09:14 PM   #2
AC0GV's Avatar
Wisconsin
The ground
Originally Posted by Niall View Post
Hi guys,
Thanks,
Niall
Are you running two wires to each light? And did you buy LEDs and is the polarity correct? Some matter.
EDIT:Forget the polarity comment, I just blew up the picture.
Old 05-29-2022, 11:14 PM   #3
There is a live wire, shown my picture, and i will ideally then connect a ground wire to either of the fastening bolts.
What is strange is that my current tester is showing that the wiring and light assembly are technically functioning, but nothing is happening with the light. Strange..
And no the bulb is not blown before someone asks lol
Old 05-30-2022, 04:57 AM   #4
Joe MacDonald's Avatar
Trailer: 1981 Trillium 5500
Make sure the 12 battery you are using is strong enough to make the light illuminate, and since you mention current tester, not Voltmeter, i take it you are putting the meter in series with the bulb? i.e. red probe on battery positive, Black probe to light feed?, light ground wire to battery negative?
Joe
Old 05-30-2022, 06:45 AM   #5
Trailer: Casita SD
Yep, you mentioned using a "small" battery to test them.
Maybe your battery voltage is sagging when you connect it to a light - still passing current, but no longer providing enough voltage to light the bulb.
JoelInTexas is offline   Reply With Quote
Old 05-30-2022, 07:32 AM   #6
From what I can make out in your pictures, it doesn't look like there is any ground wire attached to either of the mounting screws. I think I can make out another wire, (a short stub anyway,) coming out of the back, that doesn't connect to anything. The wire looks like it was cut off. Maybe that would have been your ground to the mounting screw? The wire I'm talking about would be at about "10 o'clock" in the bottom picture.
Old 05-30-2022, 01:57 PM   #7
DaveLevenson's Avatar
New Mexico
You state that the ground is through the mounting bolts. Are you using a ground wire attached to one of these bolts? If not, and if you're bolting them into a fiberglass body, then there is probably no ground connection. You'll find battery voltage on the lamp, but you'll have no current flow because the circuit is open.
If you do have a wired connection from a mounting bolt to the negative side of your battery, test the voltage between the mounting bolt and ground. If there's any voltage there, your ground circuit is open somewhere.
DaveLevenson is offline   Reply With Quote
Old 06-05-2022, 05:44 PM   #8
On any trailer that I have ever wired which is many there is always a common groundwire connected to all lights Even if you use a metal frame as a common ground you're begging for grief
fishinjimi is offline   Reply With Quote
light, lights
trailers lights not working on Scamp krboren Problem Solving | Owners Helping Owners 14 06-01-2015 12:56 AM
12vdc interior lights not working in Burro rabbit Problem Solving | Owners Helping Owners 4 03-13-2011 06:47 PM
12v lights not working Brian Tin Problem Solving | Owners Helping Owners 4 09-13-2010 10:42 PM
Running lights not working DavidS Problem Solving | Owners Helping Owners 2 09-06-2009 10:15 AM
Bigfoot trailer backup lights not working MountainHome Problem Solving | Owners Helping Owners 5 04-26-2008 10:37 PM
