01-30-2021, 04:43 PM
Trailer: Escape
Soft Start AC
I am getting tired of lugging around my larger generator and am considering installing a soft start on my Scamp AC to allow us to have AC with a smaller generator. Lets hear it, have any of you done this? Your thoughts, your opinions?
01-31-2021, 10:28 AM
Trailer: 13 Scamp
I have a scamp 13 with a 13500 ac and I run it on a ryobi 2200 watt generator. No problem. My scamp is a 2015 . But the generator has a bigger engine which can take the surge when the compressor kicks on. They do not make my generator anymore but look for a 2200 watt generator with a 2.0 engine or bigger. Also it runs my casita 17 as well.
01-31-2021, 10:44 AM
Trailer: Escape 17 ft Plan B
There are two different "soft start" options available. The least expensive is a replacement for the starting capacitor. While it will lower starting current a bit, a much better, although more expensive solution is an " Easy Start" unit. This device uses a microprocessor to lower the compressor starting current.
Some models of Dometic ACs already have the soft start capacitor built in. The Easy Start can also be added and will make a significant difference. Even when connected to a power pedestal, the Easy Start is nice - it eliminates the compressor starting "thump", and lessen the chance of opening the main or pedestal breaker if you are running close to a full load.
01-31-2021, 10:49 AM
Name: Bob & Jackie
Trailer: 13' Scamp, 17' Casita Spirit Deluxe
Soft Start
I installed the SoftStart on our 2012 Casita Spirit Deluxe over a year ago and have had great success with running air conditioner on house hold current, Honda 2200 generator when needed. Air conditioner does not make that thump sound now when it starts which is great.
Bob C
01-31-2021, 11:18 AM
Trailer: no longer looking at Parkliner,04 Honda Odyssey
I like this soft start/easy start technology but I also like my silent 120W solar panels. They work great except for AC. Reefer & hot water runs on propane. Does anyone know what size solar system and AC system I would need to make this work? Does anyone make a propane AC unit?
01-31-2021, 11:42 AM
Trailer: Escape 17B
We have a 2019 Escape 17B with factory AC, 13500 btu I assume. It runs well on an older Honda 2000i generator or on the 115/15A garage plug. We have the factory Progressive Surge guard as well and it’s happy.
I don’t recall any clunk when the AC compressor starts. I find the fan noise is high inside the RV. It certainly works well and while has not been used often it’s good to have when you need a good nights sleep.
I have been considering adding the soft start box. The power posts in older campgrounds can be a bit under rated.
Bob
01-31-2021, 12:18 PM
Wisconsin
EAsy start link
i have been running my 2017 Scamp A/C on a Honda 2200 but plan to install an easy start this year.
I like this link better. It has the install kit.(but is out of stock)
https://www.amazon.com/Hutch-Mountai...2116896&sr=8-1
01-31-2021, 02:01 PM
Trailer: Escape 17B
I just looked up my Dometic AC unit specifications on the Dometic web site. It appears my AC may have a soft start feature built in. They do not show a BTU rating for this AC . They do indicate only a 15A breaker for it. All the other units in the table show a 20A breaker and larger generator recommended.
The number in the columns are amps, the first number is the compressor current, then the locked compressor rotor amps, this is very high like 70 for most units, but only 5.6 A for my model. Then the fan current, then locked rotor fan current.
There was no mention of this from Escape when we ordered the trailer of picked it up at the factory. It looks like I don’t need the soft start and explains why I don’t recall any starting thump with it.
So check you AC model before ordering the Softstart module. If ordering a new trailer it might be good to ask about this option.
Bob
01-31-2021, 05:25 PM
Trailer: Escape
Thanks
Thanks for the input everyone, such a great group of helpful people here.
Bob thanks for suggesting that my AC might already have easy start capability. Our old AC gave up the ghost this summer and we had a new Dometic Brisk II installed in August. I will get the paperwork out and check, I might give Dometic an email as well.
01-31-2021, 05:31 PM
Trailer: Escape 17B
Good luck, I just noticed this when I looked up my model number on the Dometic website. I did notice that the AC unit only drew about 10 Amps while it was running, and the generator hardly coughs when it starts up.
Bob
01-31-2021, 11:53 PM
Name: Bob & Jackie
SoftStart RV
Bob C
Just to clarify that the SoftStartRV is what I installed to replace stock soft start that came with my trailer. Air conditioner starts easier and overall performance is better.
02-01-2021, 10:28 AM
Bob
Again, there is a difference between the Dometic ACs that have "Soft Start" and the Micro Air Easy Start or SoftStartRV module. Adding the Micro Air Easy Start module replaces the compressor starting capacitor with a microprocessor controlled start up. This will lower the starting current below what the standard or soft start Dometic AC requires. It can be added to a Dometic with the factory soft start and will both lower the starting & restarting current and eliminate the start up thump that most Dometic ACs exhibit when the compressor kicks on.
I've added A MicroAir Easy Start to my 2017 Escape 21 with a Dometic AC that has the factory built in soft start & it is a definite improvement.
02-02-2021, 02:42 AM
Trailer: Bigfoot
Everywhere
Originally Posted by flaco
I like this soft start/easy start technology but I also like my silent 120W solar panels. They work great except for AC. Reefer & hot water runs on propane. Does anyone know what size solar system and AC system I would need to make this work? Does anyone make a propane AC unit? �� ��
Big. The AC pulls on the order of 1200W, or 100A at 12V. So, you need an inverter capable of that plus some more, batteries that can handle a 100A discharge, and probably 1000W of solar bare minimum if you really want to run it as needed instead of here and there. I have 500A of batteries and 800W of solar with a big inverter, and I can run the A/C a little, but definitely not all day or all night. Probably something like 1200Ah of Lithium batteries and 2000W of solar to be able to just use it when you want, and that's obscenely expensive and won't really fit in and on a small trailer.
Switching to something like a high-efficiency mini-split might cut 20-50% off of those requirements, which makes it more doable, but that's a project itself.
02-02-2021, 09:31 AM
Thanks for the great info Elliott. I think I will stick to fans or get that mini split and a much larger camper!🍻
02-06-2021, 11:16 AM
Trailer: In The Market
AZ
My Little Honda Generator
I have a Scamp 16 with factory microwave, Dominic 3 way refrigerator/freezer, and a rooftop-mounted easy-start A/C unit. My little Honda EU 2200i Companion 30a has an electrical receptacle that accepts the 30 amp shore power cord from my Scamp and powers up all three appliances at the same time as it charges the battery. The easy-start A/C addition really makes a significant difference in reducing the size of your generator.
02-06-2021, 11:55 AM
Wisconsin
My Honda is a twist lock
Don't you need an adapter?
02-06-2021, 12:00 PM
Wisconsin
SOft start / Easy start on Amazon
I ordered one this week and have already received two. I clearly ordered just one but got two in two totally different packages with the same return address. They claim to have sent a pick up order for the spare. (The box is labeled both soft and east start.)
02-06-2021, 12:55 PM
AZ
No, if your shore power cable plug is the type typically found on most RVs. If not, then you will need to buy an adapter.
