10-14-2020, 07:33 AM
Solar Panel Mounting System
I'm looking to install a rigid solar panel on top of my Boler 1700 and need to devise a mounting system that accounts for an overhang where the panel will be 3-4" from the roof of the Boler. Any thoughts on how to safely secure the panel at the overhang section?
Here are some photos: https://drive.google.com/drive/folde...LQ?usp=sharing
Thanks!
10-15-2020, 12:02 PM
Harry..
I recently mounted a couple of 50watt panels on my Trillium.. I'll take a couple of pics later today and post them here for you to have a look at..
Chris from Comox..
10-15-2020, 12:26 PM
Panel Mounting?
Hello,
For living in far north in Ontario I would not mount the panels on the
roof. The angle of the sun greatly decreases the panels' output.
Portable panels would probably work better as they can be
angled toward the sun for max output and easily cleaned when dirty.
Of course I don't know your physical strength or your tug's
storage capabilities...
Good Luck,
Uncle Larry
10-15-2020, 12:49 PM
I have 45w on the roof of my Campster made up of 3 15w Harbor Freight panels. The previous owner added feet to a peace of plywood the same dimension as the combined panels, then put 4 bolts through the roof to secure the panels. The feet account for any curvature of the roof and hold the plywood about a half inch above the fiberglass.
I don't like how he weatherproofed the bolts through the process sealing with silicone so I am removing the silicone and using gasket washers on the top and bottom with nuts. I did this to the one corner that leaked and solved the problem. The other three corners are on my 2do list.
10-15-2020, 01:10 PM
I use 1/8" x 1.5" aluminum bar stock and bend it in a vise. You can get a fairly close radius. I usually end up with a 1.5" x1.5" foot bolted to the roof with 1/4" bolts and have had the 100W and 180W panels elevated 3.5" without an issue. That's just what I have done without an issues but YMMV
Eddie
10-15-2020, 02:22 PM
Trailer: Casita 17 ft SD
Attaching the Solar Panel
This is the way I attached an 80 Watt solar Panel to my Casita.
Parts include four pieces of aluminum 1 1/2 inch angle, Pop rivets, bolts caulking.
10-15-2020, 02:35 PM
Trailer: Escape 19
CA
I used a more complicated setup with Thule roof-rake components on my Escape 19. Each rail is connected to the roof with six bolts/nuts. I used four 80w panels, the setup gives me the ability to get up to 640w, with another 320w in the front that I’m not sure I’ll ever do, and when technology change it will be easy to replace the panels, after all a fiberglass trailer should last twenty years or more.
10-15-2020, 08:34 PM
Trailer: Escape 21 - Felicity
Wow - if you got the angle right on those panels you might get enough lift to loft the trailer!
10-15-2020, 09:47 PM
Trailer: Escape 19
CA
What angle? these are flat.
10-21-2020, 12:56 PM
Trailer: Scamp 16'
Go to amsolar website. I used their hardware on my Scamp. 2 100w It works great.
Thanks!
Go to amsolar web site they have all the hardware for you. I have 2 100w panels on my Scamp 16’. They work great.
Rich
10-21-2020, 12:59 PM
Hey there. I have a similar roof line with my trillium.
I know that your roof fan is creating space constraints, but I would recommend against mounting the panels across the roof line. I don't think the fibre glass has enough integrity to deal with that kind of force when on the highway.
If you are going to do it, I would suggest a mounting plate from the inside and an air dam to keep the air from speeding up under the panel.
I've attached an idea of the air dams from my install.
10-21-2020, 01:14 PM
Trailer: U Hall VT
I mounted our 55 wat panel on our U-haul with 4 aluminum angles, worked great!
10-21-2020, 03:09 PM
Panels on Our Casita with VMB - No Bolts or Holes!
We've been across the country twice and made several local AZ trips. If these panels fly off, I'm going to have four holes in our RV.
Dealing with angles and overhangs is a challenge. I used Z-brackets which I offset with a small piece of hard rubber/plastic toilet/furniture wedges.
Brackets:
https://www.ebay.com/itm/8-Pcs-Solar...72.m2749.l2649
10-21-2020, 05:35 PM
Trailer: 1977 Scamp 13'
I mounted a 100W solar panel to the roof of my 13' Scamp using aluminum angle brackets (1-1/2") and 3M VHB tape. 6 years later, still holding strong.
10-21-2020, 05:41 PM
Trailer: In the market
New Mexico
Solar mount
Check out Slim Potatohead on Youtube he had the same problem on his new Fiberglass camper. The way he did it seems really secure.
10-21-2020, 06:19 PM
Trailer: 2013 Escape 19
Best Trillium solar panel installation I have seen was on the front rock guard. You can find pictures on the Trillium FB page. Slim's method looks good for a newer Trillium. The old ones the roof is just too flimsy IMO.
10-21-2020, 07:02 PM
I put a 48W panel on the front window cover.
Doug
10-22-2020, 05:16 PM
hieronymus,
I installed (4) 100 watt Renogy "compact" panels on top of my 17' Casita. I was able to mount blocks of marine grade plywood encased in fiberglass to the roof of my Casita using Sikaflex 252 adhesive. I then attached the solar panels to the fiberglass/wood mounts using AM Solar mounts (AMSolar.com).
The AM Solar mounts have tilt bars that permit you to change the angle of the panels.
I made only one hole into the fiberglass in the installation. That was making a hole for the cables to enter the Casita body. I used an entry gland using VHB to adhere it to the fiberglass roof.
I've traveled 6,000 miles so far and its held up perfectly.
10-25-2020, 06:22 PM
Trailer: 2017 Escape 19
New Hampshire
I installed a Renogy 270w panel on our Escape 19 in 2017. The method I used was also an “overkill mounting solution” (shown in photos) but I’m happy with how sturdy, protected and well sealed the install is. In order to create a large level mounting platform which straddles the hump in the center of the roof, I installed two 2x3 rectangular aluminum tubes fore and aft, attached with four 1/4” bolts through the roof in inconspicuous places, and then bolted aluminum angles across those rails to which the Renogy provided mounting brackets attach. By not drilling any new holes in the solar panel itself, it preserved the warranty and the aluminum angle protects the panel from accidentally backing into a tree limb or roof overhang.
10-26-2020, 12:23 AM
Trailer: Escape 19
CA
That looks solid, and with such a large panel it's a good thing. I probably could have saved some money using this method instead of the Thule components I used on my Escape 19.
