Sunsaver 10 error code - Fiberglass RV
Old 02-21-2020, 04:54 PM   #1
Idaho
So my Sunsaver 10l Solar Controller is giving me an error code. I’ve had my Lifeline AGM battery plugged into a smart charger all winter like I always do. This is the first time I’ve had error codes with this in the 8 years I’ve had it. It’s sequencing between red & green then yellow. According to the manual it means 3 things. It’s either “external wiring error, load over current, or load short circuit”. But I don’t know what that all means. What should I check first? Thanks in advance.
brownrecluse is offline   Reply With Quote
Old 02-27-2020, 08:48 AM   #2
Joe MacDonald's Avatar
Trailer: 1981 Trillium 5500
IMO,
load over current might represent batteries that are too low, and trying to draw more than your controller can put out
load short circuit could mean a short in the wires going to the battery, or a battery that has failed
external wiring error-??? did you change anything when you set it up for the winter?
I would disconnect from everything and check battery voltage, if low manual charge, if ok, reconnect solar and see if error goes away check all wiring for loose,burnt connections
Old 02-27-2020, 09:12 AM   #3
We had the same problem on our Sunsaver controller a couple of summers ago. It was simply a loose connection on one of the fuses.
Shawn B. is offline   Reply With Quote
Old 02-27-2020, 11:16 AM   #4
Idaho
Thanks. I changed all the fuses, and didn’t notice anything weird. But maybe I missed something. I’ll poke around again.
OBD Code Reader Steve Hammel General Chat 15 03-04-2013 11:32 AM
Paint code for (beige) 1980 Trillium trailer Joe Loiacono Care and Feeding of Molded Fiberglass Trailers 1 06-14-2007 04:58 PM
