These Solar Generators Are So Confusing - Page 3 - Fiberglass RV
Old 05-20-2022, 01:51 PM   #41
I have an Indel B65 12 vdc compressor fridge. - Dan Foss compressor — .my current current draw is .1 amp sitting idle and 2.1 amp with compressor running — .4 amp interior light. This is based on the readings of a Victron smart shunt.
joecf is offline   Reply With Quote
Old 08-16-2022, 03:29 PM   #42
Virginia
My trailer doesn't have a battery and I don't think it ever did, my grandparents used shore power at campgrounds. I am having trouble with some of my interior lights and am considering rewiring, changing the fixtures to LEDs and updating the power converter. If I do that, it seems to make sense to add a battery and some kind of solar possibilities, or at least setting it up so that could be added. Seems like a 100Ah Lithium battery runs around 1000$ USD and one of those Jackery or portable type ones runs approx the same. One of those has it's charger on board and you don't have to get a separate one, and can those still be plugged in to run your interior lights and outlets? Wouldn't it make sense to just get one of those all in one? I'm probably missing something but would love to hear your take on it. https://www.amazon.com/EF-ECOFLOW-Po...-2-spons&psc=1
Jamie June is offline   Reply With Quote
Old 08-16-2022, 03:34 PM   #43
John in Santa Cruz's Avatar
Trailer: Escape 21, behind an '19 Ferd Expedition
Mid Left Coast
the power converter *is* a charger. if you're going to go lithium, you want a power converter like a PD46xx that has the lithium mode jumper.
Old 08-16-2022, 03:41 PM   #44
Virginia
So if I want to set up/fix wiring now, and plan to add battery and potentially solar later, what are some converters I should consider? My original 1978 one is a Progressive Dynamics "Solid State" that I guess all the Trilliums had.
Old 08-16-2022, 04:46 PM   #45
Mid Left Coast
Solar is nearly always a separate module, two wires to the solar panels themselves, and 2 wires to the battery.
re: power center, I don't know if you can get a modern converter that fits in your old power center. This is a complete power center, with a 45A converter, lithium or lead acid compatible, AC distribution breakers, up to 12 fused DC circuits, etc.
https://www.progressivedyn.com/pd4000-series/
generator, solar
Trillium Manufacturers = Confusing Roger C H General Chat 51 08-31-2013 04:18 AM
Brake Control Adjustment: Confusing Lawrence W Towing, Hitching, Axles and Running Gear 1 08-10-2010 09:07 AM
So many confusing choices for newbies Frank G. Care and Feeding of Molded Fiberglass Trailers 21 03-16-2007 12:15 AM
solar vs. portable generators. both? Francine P Electrical | Charging, Systems, Solar and Generators 8 07-06-2006 04:55 PM
